Gimme 5 years
Re: Gimme 5 years
yeah, well the black bits are black and the grey bits are montana grey - with the door closed the shed is pretty dingy and the yellow of the lights doesn't help...probably a good day for the hardware shop...I'll see what I can do
Re: Gimme 5 years
bit better with some white light fluros
Re: Gimme 5 years
another delivery - it's been good shopping weather
Re: Gimme 5 years
Under the white fluro that looks like the same as what mine were from factory, ute and van.
Are the shocks heavy duty gas Monroe Wiley?
Re: Gimme 5 years
Hi Clay, the shocks are Gabriel Guardian gas shocks - good price at Superspares. Patrick
Re: Gimme 5 years
I see the bastard file coming out to fit the fronts. Good brand going back Gabriel.
Re: Gimme 5 years
I don't use paint stripper much - but for wheels - yep...then some paint
- wheels.jpg (64.12 KiB) Viewed 784 times
Re: Gimme 5 years
Neat Patrick
They look red and fast
Re: Gimme 5 years
Now you’re tempting me paddy
Re: Gimme 5 years
Yeah, those two wheels came from a fella in Sydney who happened to be coming this way...they cleaned up well.
Today, I put some air in the tyre of a wheel that I had previously painted and had sitting outside. It started bubbling water around the valve and bead...hmmm...got the tyre taken off - it's wet in there and has been rusting. I tidied it up but not sure it'll be used, if I come up with enough other better ones.
Now, I'll take the wheels off the ute one at a time and decide (at least I know they hold air - though two have tubes). I put my other painted wheel (the HR one) on the ute, so I could paint up another EK one.
Patrick
The previous owner must have been environmentally conscious
Patrick
Re: Gimme 5 years
Good old retreads hey..... with a name like “Rodgers Retreads” I’m sure he was an honest bloke?
Re: Gimme 5 years
I started stripping another wheel but then the weather turned nasty (and my workspace isn't hail-proof)
...but what can you do? the clothesline is where I hang out
boom boom
boom boom
Re: Gimme 5 years
drilled some extra holes and sprayed fish oil everywhere that's been welded (front, driver's side, rear) - another job that you don't see - unless you look on the concrete (and my clothes)
Re: Gimme 5 years
gave the petrol tank a bit of a cleanup
could hear something loose inside ... so I shook these out - home made fuel catalyst?
