Moderators: reidy , Blacky
EKSPCL
Posts: 794 Joined: Sat Mar 15, 2008 11:36 pm
Post
by EKSPCL » Mon Jun 20, 2011 8:03 pm
When I got the EK she was partially disassembled.
Some of the parts I don't seem to have are the all the wires/plugs that go to the taillights, rear indicators and reverse lights.
The globes fit in from behind the lenses, but I can't find any pics in the manual, or on here, of the plug that goes in from the wiring side
I have found the fittings for my front indicators at Autobarn.
Hands up who can help
My 6yr old daughter said
jack_fc
Posts: 141 Joined: Sun Nov 18, 2007 9:32 am
Post
by jack_fc » Mon Jun 20, 2011 8:20 pm
check the thread in 'electrical' - 'indicators' by FBVAN; if EK fittings are same as FC, these are them
. look at the Narva site under 'globe holders', I think you can get the metal-bodied globe holders to suit either single or dual filament globes
hope this helps, jack
EKSPCL
Post
by EKSPCL » Mon Jun 20, 2011 8:48 pm
Thanks Jack.
I found the front indicators thanks to your help on my other post.
I can't work out if any of the plugs on the Narva site will fit the taillights though.....
http://www.narva.com.au/products/browse/globe-holders
This is what I have........
If the fitting is one of the ones on the above Narva site, which one?
Forgive me if I'm not seeing something obvious
Posts: 13828 Joined: Tue Jul 20, 2004 8:58 am
Post
by Blacky » Mon Jun 20, 2011 10:39 pm
The rest of the fitting should be on your wiring harness.
EKSPCL
Post
by EKSPCL » Tue Jun 21, 2011 5:39 am
No, that's my problem.
The guy who I got the car off has cut the wiring off the loom from the dash
I have had to re-do the wiring from the dash.
I haven't ever seen the plugs to know what they should look like
jack_fc
Post
by jack_fc » Tue Jun 21, 2011 9:20 am
EKSPCL, sorry mate, cant help with that one... it's obviously different to FE/FC taillights
fj_225
Posts: 159 Joined: Sun May 25, 2008 9:23 pm
Post
by fj_225 » Tue Jun 21, 2011 12:36 pm
hi ekspcl.i have a old loom here if its any good to you
cheers shane
EKSPCL
Post
by EKSPCL » Tue Jun 21, 2011 3:34 pm
PM sent.
Thanks
EKSPCL
Post
by EKSPCL » Sat Jun 25, 2011 3:38 pm
I've found one brake light fitting and the two indicators. Thanks again Shane
Now I know what they look like.....
I need another brake/tail light fitting and the two reverse light fittings.
I'll put this to the Parts Wanted section now.
Thanks for the help
