Gimme 5 years
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
nah, it just needs a bit of encouragement
it's only 2.7 billion years old - it'll come good
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
considered heading home but heard the road is 'blocked' 😉
Re: Gimme 5 years
:lol: :lol: :lol: :lol: :lol:
Re: Gimme 5 years
Going to affect Cummins and goings?
Re: Gimme 5 years
that looks like its thrown a CAT amongst the Perkins ......
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
I don't know when I'll head back to the ACT, so I wrapped some cardboard around the wheels, logged onto truckit and freighted them home
Re: Gimme 5 years
He he, I'll pop round and get them off the porch!!
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
too late Brett, missus got son to put them around the back
here's a pic instead
seagull joke.jpg (44.07 KiB) Viewed 828 times
Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
starting to warm up so I'm back in Canberra ... lots of deliveries while I was away ... only opened a few so far
some steering bits from Clay :thumbsup:
steering bits.jpg (67.69 KiB) Viewed 768 times
and thanks for throwing in some brake bits Clay :thumbsup: :thumbsup:
brake bits.jpg (39.75 KiB) Viewed 768 times
so there's one less thing that needs maintaining, I got a pertronix ignitor and flame thrower coil
pertronix 1.jpg (81.68 KiB) Viewed 768 times
went to the spares cupboard (saw I've now got 5 distributors) and made up a pertronix distributor (then the one currently in the car can be a slip-in spare)
pertronix 2.jpg (68.92 KiB) Viewed 768 times
and I heard that aussie speed alloy rocker covers quieten tappets (so I wont have to adjust them) :wink34:
rocker cover 1.jpg (101.65 KiB) Viewed 768 times
Patrick
Re: Gimme 5 years
Lot's of goodies Patrick. Glad you are back - you'll have to dry that wet ute out😂
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
Brett027 wrote: Tue Oct 19, 2021 9:05 pm Lot's of goodies Patrick. Glad you are back - you'll have to dry that wet ute out😂
Hi Brett, nah all dry inside ... paint, glass and rubber all waterproof ... bit of pollen on the outside though. Patrick
Re: Gimme 5 years
half your luck - it hasnt warmed up in Perth yet :shock: :shock: :shock: I am still hiding in Gove until the rain stops .....
Re: Gimme 5 years
Blacky wrote: Tue Oct 19, 2021 11:05 pm half your luck - it hasnt warmed up in Perth yet :shock: :shock: :shock: I am still hiding in Gove until the rain stops .....
Not exactly warm here either Blacky. 2° overnight a couple of days ago😁.
I wonder how we cope breathing in the amount of pollen that is in the air when you see everything coated in yellow some days. Fortunately this spring there has been so much rain that its washed off every second day.
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
FJWALLY wrote: Fri Jan 08, 2021 7:06 am I can sense fluffy Dice coming on!
Yeah, I did it
fluffy dice 1.jpg (47.45 KiB) Viewed 729 times
They can also hang here so I don't get the fines and demerits
fluffy dice 2.jpg (52.16 KiB) Viewed 729 times
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
I recently adjusted the tappets to 8 thou and 12 thou 'hot'.
I was putting on the rocker cover today, so I thought I might as well check the 'cold' gap because I've never seen it listed anywhere.
So at 20 degrees ambient temperature my engine's 'cold' gaps are 7 thou and 10 thou. Then I got the engine up to operating temperature and double checked they were still at 8 thou and 12 thou 'hot'.
The rocker cover came with h-nuts but no seals... I phoned the supplier and they said Aussiespeed don't offer a solution - and people make up their own seals. Another option would be longer studs and then the nuts could sit on top of the normal seals and washers (but having different thread at the head end to the nut end doesn't make that an easy fix)
You also need a bit of height or the nut hits the fins. I'll see how I go with a washer and o-ring for now ... and have a think about it
rocker cover.jpg (77.15 KiB) Viewed 682 times
Patrick
