LS1EK
Re: LS1EK
Exhaust is all in place, just need to fab up some mounts and then finish welding it together.
- IMG_7425.jpeg (1.51 MiB) Viewed 11198 times
- IMG_7412.jpeg (1.94 MiB) Viewed 11198 times
- IMG_7409.jpeg (2.54 MiB) Viewed 11198 times
- IMG_7405.jpeg (1.92 MiB) Viewed 11198 times
Re: LS1EK
Bit more exhaust spam, I added in two more v-bands as I will be getting the exhaust ceramic coated and it was too long to go in their tank.
I also started fabricating up the brackets to mount the car on the rotisserie for the last time. Yep time to finish up the up the underside and engine bay and lay some paint down.
I have included a picture of the tacking clamp I made for tacking exhaust together. It allows you to tack the joint with the clamp holding it in place. They are tube mounting clamps made from stainless. You can buy them online, I will also use them for mounting the exhaust.
- IMG_7765.jpeg (2.6 MiB) Viewed 10966 times
- IMG_7764.jpeg (2.72 MiB) Viewed 10966 times
- IMG_7763.jpeg (1.58 MiB) Viewed 10966 times
- IMG_7761.jpeg (1.98 MiB) Viewed 10966 times
Re: LS1EK
I wonder how many cases of Boags I would need to supply if he started work at one end of my driveway and worked his way down?
Re: LS1EK
I would say zero - He is from the south and I would assume has never had a can of Boags in his lifeHarv wrote: Tue Nov 12, 2024 7:56 amI wonder how many cases of Boags I would need to supply if he started work at one end of my driveway and worked his way down?![]()
Cascade however may be a different story ........
Re: LS1EK
LOL, I will drink either brand of beer these days but not enough time for my own jobs.
Finally got the EK on the hoist, time to strip it ready for final tidy up underneath and then painting. Fuel lines completed and brake lines mocked up.
- IMG_8465.jpeg (2.38 MiB) Viewed 10742 times
- IMG_8469.jpeg (2.48 MiB) Viewed 10742 times
- IMG_8466.jpeg (2.25 MiB) Viewed 10742 times
- IMG_8467.jpeg (2.12 MiB) Viewed 10742 times
