LS1EK
Re: LS1EK
Great work Taz,
Fabricating everything like this takes years, it will be well worth it once you are done.
Re: LS1EK
Very nicely executed air intake.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Christ, am I just lucky or are all doors gaps as bad as mine along the bottom. I have the gaps pretty good along the top areas but along the bottoms at the rocker that are so far out.
I know I was going to have to doing some sanding and add some metal but wow, they are pretty bad. The last picture shows where the meet at the middle.
I also ended up splitting the bottom dog leg on the rear door to pull the wheel arch and rocker panel edges out so they meet with the door edge.
Is it common practice to pull the door edges out as they all seem to curve in right on the outer edges.
Re: LS1EK
They were pretty horrible straight out of the factory mate, and 60+ years later they wont have gotten any better .....
Have you thought about removing the divider strip between the front and rear doors ? Gives you one less gap to fettle and makes for a cleaner look - I think EK283 did it on his rig ?
Re: LS1EK
Yes I did mate,
Around this link there are the panel gaps i did.
Open the image in a new window and the photo bucket dissapears.
viewtopic.php?t=882&start=360
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Right, so been trying to get the exhaust finished but hit a few snags with getting the cats up high enough. This job has taken wwwwway to long but the end is in sight.
Ended up trimming some material of the gearbox cross member. This allowed me to get everything up higher. Just waiting for a donut to arrive so I can cut some short radius elbows from it.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Oh, I have also made an engine cover which should go well with the air intake and rockers covers.
I am thinking of getting an ally plate with a design either laser cut or CNC into it to go on top of the engine cover. Anyway plenty of things to do before that will happen.
Re: LS1EK
Holy crap you have pretty much just built a whole new car under an EK roof :shock: :shock:
Good progress mate :thumbsup:
Re: LS1EK
Blacky wrote: Wed Sep 25, 2024 10:37 pm Holy crap you have pretty much just built a whole new car under an EK roof :shock: :shock:
Lifted up the radiator cap, drove the EK out and drove a new one back in underneath.
Cool progress Taz.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Success, all fits and aligns nicely with plenty of clearance. I still need to do the drivers side but I have already cut all the elbows to length using the passenger side as a guide.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Almost there, stretched for time but the end is near.
Re: LS1EK
Pretty exciting Taz.
briby
Re: LS1EK
Post by briby »
Great stuff Taz, can't wait to see this beast with all it's intricate detail. :clap:
FB Restomod V8 Sedan
Re: LS1EK
Fantastic work Taz
melly
Re: LS1EK
Post by melly »
That’s really impressive, well done Taz
