Parcel Shelf Under Glovebox
I know this topic has probably been discussed before but when I did a search I didn't find what I was looking for.
Does anybody have a short parcel shelf that they could trace and send me or maybe someone in WA or anybody have one for sale :ebiggrin: also fitting instructions :roll:
I know I'm asking a lot, any assistance greatly appreciated.
FJWALLY
Re: Parcel Shelf Under Glovebox
Post by FJWALLY »
There was a short version?
Hey Wal when I did the search there was talk of a long and short the short let you have the heater and the long one must have come right across to near the steering column.
I just looked on evil bay and greedy bitz want $500 for apparently a new one :crazy:
FJWALLY
Post by FJWALLY »
I was looking at mine yesterday Neil - I haven't actually test fitted it but it's only about 600mm long so should not interfere with heater - there has been a few pop up recently - there is also a guy making brand new ones for 200 or 250$ I believe which is about the price of a half decent original
ive got a template here Neil, Mick made it a couple of years ago. I made the parcel shelf in my ute
These are the fitting destructions for EJ/EH... I don't have FB/EK, but they should be similar.
7425190 Parcel Shelf EJ and EH Holden 1 of 2.jpg (163.03 KiB) Viewed 4786 times
7425190 Parcel Shelf EJ and EH Holden 2 of 2.jpg (115 KiB) Viewed 4786 times
Thanks for destructions Harv appreciated.
Hi Blacky that's great mate I would like to borrow it if that is ok when I get a chance to catch up with you, I'm off shore from 1st August and most of the month so will give you a buzz when I get back, thinking of using to to put my computer and relays on that way keep full glovebox, I'll just make a cover and put over them.
FJWALLY
Post by FJWALLY »
Did a quick look at mine in position - doesnt seam to follow firewall very well - maybe mine is not fb ek? ImageImage
Here is one I reefed out the ute I think. Imagebring our yer parcel trays everyone yeah.
FJWALLY
Post by FJWALLY »
Errol62 wrote:Here is one I reefed out the ute I think. Imagebring our yer parcel trays everyone yeah.
Looks right then - did you notice if they bolted through the firewall?
I recall that the horsehair trim thingy comes in to play here.
And I’m sure they fit with the warmaride, sitting slightly below the bottom of the fan housing with a S light overlap.
Yes rob they screw to the firewall and through the kick panel trim on the side. Use a tapper on the side. You can use gutter bolts on the firewall or use self tappers and grind off the end in engine bay for a clean look.
Passengers may complain of a reduction in space in the foot well. I’m not a huge fan but in a ute maybe more space efficient. Neil your application sounds like a hood solution. Damn newfangled computers man, I don’t know you young boy racer hot rodders.
Thanks guys and Wally yours does look slightly different to Clay's.
Wally do you have any contact info on the guy making them???
FJWALLY
Post by FJWALLY »
looking at them closely they look the same apart from mine looks like the edge between the two tabs on the back edge has been rounded off a bit - might of been something there they wanted to clear perhaps
Sorry I didn't save his details so could be mistaken - The only thing special about them is the alloy front edge which ties back to the edge they used on the sun visors - pressed on - the rest is just steel sheet and very basic - if you could bend one up and weld a bit of round bar to front edge you would get a similar result.
Mine is badly pitted on the top surface so once cleaned up I will probably use a texture coat over it or glue a rubber sheet down to act as a anti-slide.
Does anyone know what was the original material they had on the top surface? Earlybitz one looks like he's using hood liner material.
FireKraka wrote: Mon Jul 29, 2019 10:34 am Thanks guys and Wally yours does look slightly different to Clay's.
I don’t know the original trim but I used a bit of surplus seat vinyl. The hood lining material will get grubby quick.
