Moderators: reidy , Blacky
TAZ
Posts: 376 Joined: Wed Sep 23, 2015 9:32 pm
State: TAS
Post
by TAZ » Thu Jun 13, 2019 11:23 pm
Gave a pipe a bit of a clean up. Came very nice and should look grouse once ceramic coated.
I also finally got the airconditioner condenser required to fit behind the grill and under the bonnet catch bar.
I was stuck for height but sourced this one which is only 160mm high but 60mm thick. It will fit perfect.
TAZ
State: TAS
Post
by TAZ » Sun Jun 16, 2019 12:39 am
Pipes are all done. I will need to cut some more steel out on the drivers side to clear the two rear pips.
Posts: 2680 Joined: Thu Mar 16, 2006 9:51 pm
Post
by EK283 » Sun Jun 16, 2019 7:21 am
Nice work Taz,
They take a lot of time to build but well worth it in the end. Ceramic coating will keep the temperature down a lot as well.
regards Greg
Posts: 11599 Joined: Sat Dec 06, 2014 2:44 pm
Post
by Errol62 » Sun Jun 16, 2019 8:18 am
Great work Taz. Keep at it mate.
Posts: 2782 Joined: Fri Jan 24, 2014 11:12 am
Post
by FireKraka » Sun Jun 16, 2019 8:22 am
Nice Taz you have a lot more patience than I do and they certainly will look good when they are ceramic coated mate.
TAZ
State: TAS
Post
by TAZ » Sun Jun 16, 2019 8:05 pm
Took the old girl out for some vitamin C
TAZ
State: TAS
Post
by TAZ » Mon Jun 17, 2019 12:24 pm
TAZ wrote: Sun Jun 16, 2019 8:05 pm
Took the old girl out for some vitamin D
TAZ
State: TAS
Post
by TAZ » Fri Jun 28, 2019 5:06 pm
Wipe motor finally mounted. Engine, gearbox and front suspension are out. Time to finally finish off the engine bay and fire wall.
Posts: 14211 Joined: Tue Jul 20, 2004 8:58 am
Post
by Blacky » Fri Jun 28, 2019 9:38 pm
love your work mate - be good to see this beast on the road
TAZ
State: TAS
Post
by TAZ » Sat Jun 29, 2019 12:50 am
Fire wall almost finished. Drivers side chassis rail done.
Post
by Errol62 » Sat Jun 29, 2019 12:55 am
Neat job on the front rail Taz.
TAZ
State: TAS
Post
by TAZ » Sat Jun 29, 2019 7:25 am
Errol62 wrote: Neat job on the front rail Taz.
Cheers mate. Getting there slowly.
TAZ
State: TAS
Post
by TAZ » Sat Jun 29, 2019 7:26 am
Blacky wrote: love your work mate - be good to see this beast on the road
You and me both Blacky. Money is the big handbrake at the moment
TAZ
State: TAS
Post
by TAZ » Mon Jul 01, 2019 10:40 pm
CHOPPED wrote: Sat Sep 02, 2017 12:51 am
mate it took me 2 weeks to do mine
alot more than it looks
Hey ya Chopped, just wondering did you reinforce the support on the inside where you scolloped it out to allow the exhaust pipes to pass?.
CHOPPED
Posts: 1193 Joined: Mon Feb 20, 2006 12:09 am
Post
by CHOPPED » Thu Jul 04, 2019 2:10 pm
hey man sorry mate
just seen this pm
yes i put a piece of 200 dia by 10 mm scallop in there and welded it in
engineer looked at itwhile still in its metal stage and just laughed and said
fark overkill
carry on man
looking good
Paul
HEY IT WASNT ME
