LS1EK
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Gave a pipe a bit of a clean up. Came very nice and should look grouse once ceramic coated.
I also finally got the airconditioner condenser required to fit behind the grill and under the bonnet catch bar.
I was stuck for height but sourced this one which is only 160mm high but 60mm thick. It will fit perfect. ImageImageImageImage
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Pipes are all done. I will need to cut some more steel out on the drivers side to clear the two rear pips.ImageImageImage
Re: LS1EK
Nice work Taz,
They take a lot of time to build but well worth it in the end. Ceramic coating will keep the temperature down a lot as well.
regards Greg
Re: LS1EK
Great work Taz. Keep at it mate.
Re: LS1EK
Nice Taz you have a lot more patience than I do and they certainly will look good when they are ceramic coated mate.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Took the old girl out for some vitamin CImageImageImage
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
TAZ wrote: Sun Jun 16, 2019 8:05 pm Took the old girl out for some vitamin DImageImageImage
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Wipe motor finally mounted. Engine, gearbox and front suspension are out. Time to finally finish off the engine bay and fire wall.Image
Re: LS1EK
love your work mate - be good to see this beast on the road 8)
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Fire wall almost finished. Drivers side chassis rail done.ImageImageImage
Re: LS1EK
Neat job on the front rail Taz.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Errol62 wrote:Neat job on the front rail Taz.
Cheers mate. Getting there slowly.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Blacky wrote:love your work mate - be good to see this beast on the road 8)
You and me both Blacky. Money is the big handbrake at the moment ImageImage
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
CHOPPED wrote: Sat Sep 02, 2017 12:51 am mate it took me 2 weeks to do mine
alot more than it looks
Hey ya Chopped, just wondering did you reinforce the support on the inside where you scolloped it out to allow the exhaust pipes to pass?.
CHOPPED
Re: LS1EK
Post by CHOPPED »
hey man sorry mate
just seen this pm :roll:
yes i put a piece of 200 dia by 10 mm scallop in there and welded it in
engineer looked at itwhile still in its metal stage and just laughed and said
fark overkill :crazy:
carry on man
looking good :thumbsup:
Paul
HEY IT WASNT ME
