LS1EK
Re: LS1EK
looking good Taz, do you have a beadroller in the shed or do you get the panels made up ?
Re: LS1EK
Got a eastwest bead roller. Yanky brand but made in China and still on my L platesBlacky wrote:looking good Taz, do you have a beadroller in the shed or do you get the panels made up ?
Sent from my LG-K500 using Tapatalk
Re: LS1EK
TAZ wrote:Now what do we have here, well it is my birthday later this week
Hey mate what are the dimensions of your radiator? Im looking for one to fit the same engine. Did you put a condenser with yours for a/c?
Re: LS1EK
Mounting it under the dash, $380 for a engineered bracket suit auto.Will wrote:Ok cool good to know! Have you had any thoughts on brake boosters yet?
Re: LS1EK
Zip ties
yeah naaa. I have to cut into the inner guards slightly so will fab up a new support panels that will not rely on the cross brace to hold it all together. Similar to the photo.
- 11425217_995891393767846_6297320739873054377_n.jpg (55.89 KiB) Viewed 542 times
Re: LS1EK
Wow Taz pretty cool photo; thats in an FC isn't it?
Love your work mate please keep the photos coming of your progress.
Re: LS1EK
First crack at mocking up the drivers side extractors. Looks as if extractors will be one piece as i can remove the steering shaft when installing or removing them. Still a long way to go yet as i have not positioned the collector etc. Will also need some hi-temp glue
Re: LS1EK
Hey Taz love your work mate, doesn't look like you have anyclearance between the pipe and chassis rail will that be a problem with engineer??
And I think you had better heat wrap those pipes mate along with your hi temp glue or you could be in trouble
Re: LS1EK
I have 10mm clearance at the moment, i need to use racing tape instead of masking tape so that the pipes stay in the right spot then inwill get more clearanceFireKraka wrote:Hey Taz love your work mate, doesn't look like you have anyclearance between the pipe and chassis rail will that be a problem with engineer??
And I think you had better heat wrap those pipes mate along with your hi temp glue or you could be in trouble![]()
