Singing Hydra
EKjimmy
Singing Hydra
Post by EKjimmy »
My Hydra is making a fairly audible buzzing/humming sound when the car is idling in gear-normally only a short while after warming up, though it only happens sometimes..
should i be worried? and does anyone know what causes this and how to fix it, because i hate noises
Cheers, Jimmy
Obvious one first, Have you checked the oil level in the trans?
EKjimmy
Post by EKjimmy »
yep, hard to tell but seems to have enough-getting more tomorrow just to be sure. cheers
jimmy
strogger
Post by strogger »
Hi EKJimmy,
I had the same problem with my old Hydra,
Turns out the buzzing is usually a sign of a clogged filter or that the filter has fallen off.
Basically your transmission needs a service.. (This is what fixed mine.)
Good Luck, Anthony.
Anthony..
FB/EK Car Club of QLD
www.qldfbekholden.com
EKjimmy
Post by EKjimmy »
yeah thats what i read in the shop manual :? is it an expensive repair to get done? no doubt persisting with it like this could cause further damage?
Jimmy
strogger
Post by strogger »
EKJimmy,
Service on mine cost me $160 from memory. But get some prices before you drop of your car, This way you'll get a feel if the mechanic knows what he's on about.
Cheers, Anthony..
Anthony..
EKjimmy
Post by EKjimmy »
No worries, thanks for that Anthony i'll have to get on it asap
Jimmy
Aussy Edo
buzzin box
Post by Aussy Edo »
hey mate,ive cleaned the filter out on mine after it was making the same noise which you have described,it stopped buzzing for a while b ut is still doing it occasionally so i think its a new filter for me or if i can find some one that really knows his stuff in brissy ile take it there for a service.The bloke anthony took it to and who sunny Tim recommended has shut up shop :cry: so ile keep looking 8)
EDO
One Day Hopefully!!
I know a bloke in Perth who has a good hydra for sale if anyone needs one .......
oldnek
Post by oldnek »
Sounds like a blocked or loose filter.
I would also flush the trans with clean fluid a few times to flush the converter as well after you service it.
Better still if you can find an AutoTrans Specialist that has a power flusher, he can do it for you. And your Trans fluid will be nice and red again with good smooth shifting from a clean valve body.
