What is this switch on my steering column?
EKSPCL
Post by EKSPCL »
Can anyone tell me what this switch does and how it works :?:
The switch is on the top of the steering column, next to the gearbox linkages....
I'm guessing it may be a reverse light switch :?:
If it is I can't tell how it would work, and I can't remember ever disconnecting it way back when I pulled it apart :shock:
I've looked through old posts with steering column pics and haven't seen one.
Any help would be great :wink:
My 6yr old daughter said
fc visitor
Post by fc visitor »
reverse light switch but looks like it,s missing the arm.
EKSPCL
Post by EKSPCL »
What's "the arm" :?:
There is a small piece of plastic on the back of the switch that I would guess be what controls the 'switch'.
It could be snapped off maybe. Is this meant to be longer so as it then connects with the linkages?
FB MAD
Post by FB MAD »
Yep, as FC visitor said,its the reverse light switch with the actuator arm missing.When box is put into reverse that top linkage in the photo would move the arm and actuate the reverse lights.
The missing arm is made of plastic and about 3 inches long if that helps you.Maybe its in a box of parts you have :? :? :?
EKSPCL
Post by EKSPCL »
No its not in a box.
I went out and had another look I think it's snapped off :shock:
The base of it is still there.
Looks like you can't just change the actuator. You have to change the whole switch :evil:
Where can I get one of these from?
I checked the rarespares site......... not there
FB MAD
Post by FB MAD »
Can be found on evilbay on the odd occasion but heven't seen any there for a while now.Don't think they are being reproduced to my knowledge.
EKSPCL
Post by EKSPCL »
Thanks for the speedy help fellas :wink:
I'll put up a post in the wanted section, see what happens :!:
