Oops I did it again…
Saw this during the week , Mrs Blacky has always liked these so we pulled the trigger and it’s heading west to join the rest of our toys ImageImage
Re: Oops I did it again…
It has a 235 in it but comes with a running 327 so that will most likely end up in the hole
Looks like a goer! (-8
Tough stance on that truck, looks neat. What is the extra pedal (forward of gear change lever) for?
The half-ton (3100's) are a neat piece of kit. Should fit the 327 and still have room to stand either side of it in the engine bay.
In the Shed wrote: Sun Aug 25, 2024 11:05 pm Tough stance on that truck, looks neat. What is the extra pedal (forward of gear change lever) for?
The push button on the floor is the start switch - is an early Chev thing - my 46 had one originally as well.
Is it going to stay a 4x4 mate or put anew frame under it.
FireKraka wrote: Mon Aug 26, 2024 7:21 pm Is it going to stay a 4x4 mate or put anew frame under it.
Its going to stay as close to exactly how it is as possible and still be able to be licenced - new windscreen and door rubbers are a given, the rest I will decide when its in front of me.
Got bored the other day and pulled the 327 down to see why it had no compression on a couple of pots -
valves were moving so whizzed the heads off - found this ….
That may have something to do with it Image
Original bore but it has a fair old ridge in it
Bit funky in the water jackets …
That looks like a low compression engine anyway.
327 from that era are normally small journal steel crank, the block is the key here, 2 bolt small journal and 4 inch bore. Not easy to find.
EK283 wrote: Fri Feb 07, 2025 10:14 pm That looks like a low compression engine anyway.
Yeah its atruck engine, has the governor built into the dizzy and the low comp. heads - perfect for an early Holden in WA as they base the horsepower rating on the stock engine and this would have made bugger all :ebiggrin:
Haven't pulled the sump yet but dollars to donuts its a 2 bolter.
Blacky wrote: Fri Feb 07, 2025 7:34 pm
does anybody else see an Asian man smiling at them :think: :lol: :lol:
EK DAZ
Post by EK DAZ »
Ha Ha ,yeah I thought the same.
EK DAZ
My uneduca5ted guess mate is that you found the reason there was no compression :lol: :lol: :lol:
