EK front parking lights bolts
ceej810
Post by ceej810 »
Hi can someone tell me the bolt size and thread for the removal and replacement of the near side park light fitting? :roll:
Re: EK front parking lights bolts
I think it may be 3/16" BSW
Errol62 wrote: Mon May 08, 2023 1:56 pm I think it may be 3/16" BSW
I suspect your right 3/16”
Dr Terry
Post by Dr Terry »
BSW threads weren't used on Holden's. It is more likely 3/16" UNC.
Dr Terry
ceej810
Post by ceej810 »
Thanks the 3/16 UNC looks right I will try and get them.
Guilty as charged, of using Whitworth threaded bolts on occasion on my Holdens.
You, and every farmer in the country as well.
10-24 UNC (aka 3/16" UNC). 3/16" Whitworth has the same pitch . . . mumble mumble . . . thread angle five degrees different . . .
The three that hold FB parking lamps in are #10-24UNC. The FC/FB/EK lens screws are #8-32UNC.
Rob’s back. Me and every OTHER farmer you mean. That’s where my welding technique comes from as well. Point, close eyes, weld, repeat. Occasionally confusing steps two and three….
Dr Terry
Post by Dr Terry »
ardiesse wrote: Tue May 09, 2023 6:07 pm You, and every farmer in the country as well.
That 5 degrees can sometimes be a real pain. The Whitworth bolt is 5 degrees "fatter" in the teeth which makes it quite tight when threading into the hole. Quite often I've just run a Whitworth tap thru the hole if I'm desperate.
Dr Terry.
