Demister Vent Hose
Demister Vent Hose
Can anybody tell me if I can buy demister vent hose form bunnings or Clark rubber or somewhere else instead of having to buy from mister greedy on evil bay :roll:
Re: Demister Vent Hose
can get a modern version from Rares - 38$ a length and you need two - it's a bit plastic feeling but for a resto mod should work well mate
viewtopic.php?f=2&t=23266
Harv wrote: Wed Apr 03, 2019 7:17 am
Errol62 wrote: Tue Apr 02, 2019 10:14 pmand I’ve heard the convoluted tubing is dear now days,
The PHD-40ML hose is still available from eBay or Repco. About $30.
I think Andrew might mention it in his guide:
viewtopic.php?f=29&t=12061
...and most importantly the ebay link to phd-40ml hose
https://www.ebay.com.au/sch/i.html?_fro ... =0&_sop=15
Thanks for your replies guys very helpful once again.
yeah Sorry - it was Repco I got mine - not rares as mentioned above.
Only issue with the Repco duct is you need hose clamps to hold it on as they are slightly larger - I believe the original is 1.5 inch (38mm) whereas the new Repco hose is 40mm. That was my experience anyway.
I found that the 40mm hose fits well inside the rubber repro heater ducts down on the heater. It was pretty loose though on the demister ducts up under the dash. I wrapped duct tape around the demister duct inlet pipe stubs until they were thick enough, then slid the 40mm hose on without clamps.
Must have been the only time I have ever used duct tape on an actual duct :oops: .
59wagon
Post by 59wagon »
Harv wrote:Must have been the only time I have ever used duct tape on an actual duct :oops:
I use it on ducks all the time
I'm worried what you do with those Ducks Bones after wrapping them in Duct tape :esurprised: :crazy:
I need the ducting so that I can fit the little electric demister that I have purchased 12v 600W 40mm outlets, picked up some PHD-40ML from Repco yesterday they had to sorts 40ML and 40MS so I assume by the look of them that 40ML the L stands for Long and the MS S stands for short :wtf:
Demister
I've popped the switch out and extended the wires so that I can remote the switch.
Hey Neil,
That is a very compact heater you've got there. What size cables are you running for that given it is rated at a whopping 600 watts? That is some serious current draw.
Dr Terry
Post by Dr Terry »
600 W !!! That's 50 Amps @ 12 V.
You'll need an extra alternator just to run the heater element.
Dr Terry
Dr Terry wrote: Wed May 29, 2019 10:24 am 600 W !!! That's 50 Amps @ 12 V.
Dr Terry
Yep, that was my calculation too, plus the wee current drawn drawn by the fan.
His v6 alternator is 85a factory
Thanks for the concern guys :thumbsup: but I don't believe it is 600W really have a look at the size of the cables coming out of it :esurprised: :wtf:
It appears to have 2 small computer fans in it and not sure of the heater elements.
Because its chinese i tested it as soon as I got it by just holding the cales against a spare battery terminals and it seemed to go ok however me being a grease monkey and not an electricians a hole may mean I am totally wrong.
I know one of the photos says 24v but the one I received is 12v as I stipulated when ordering.
Looks like a neat solution to pass rego Neil. Would be nice if you could switch between windscreen and floor.
Clay
