Thermo housing plug
Thermo housing plug
Early red motor 149, 179 lower thermostat housing plug if anyone has one lying around. Imagecheers
Clay
59wagon
Thermo housing plug
Post by 59wagon »
Any idea what size, Clay? I’ve got a few bsp plugs and others lying around.
John
Re: Thermo housing plug
I think around 7/8 coarse thread John. Red blue black motor heater hose union and temp sender match.
I have employed a temporary solution and will probably end up installing a temp sender instead of the plug.
Maybe I don’t need this now. Doh!
Thanks anyway.
Clay
59wagon
Post by 59wagon »
couple of bucks at Pirtek or the like
thanks blacky
Dr Terry
Post by Dr Terry »
Be careful not to use a BSP plug here. The correct thread is 1/2" NPT, which is close to 1/2" BSP but not close enough. I've seen these housings split open by fitting a BSP plug.
Dr Terry
Are these 1/2"NPT, or 3/8"NPT?
MasterParts reckons 3/8". I thought the 1/2" pipe plugs were on the water pump, but could be wrong.
