Moderators: reidy , Blacky
Posts: 11626 Joined: Sat Dec 06, 2014 2:44 pm
Post
by Errol62 » Sun May 06, 2018 3:26 pm
Early red motor 149, 179 lower thermostat housing plug if anyone has one lying around.
cheers
59wagon
Posts: 645 Joined: Sun Jul 27, 2014 11:40 am
Post
by 59wagon » Sun May 06, 2018 3:54 pm
Any idea what size, Clay? I’ve got a few bsp plugs and others lying around.
John
Post
by Errol62 » Sun May 06, 2018 5:12 pm
I think around 7/8 coarse thread John. Red blue black motor heater hose union and temp sender match.
I have employed a temporary solution and will probably end up installing a temp sender instead of the plug.
Maybe I don’t need this now. Doh!
Thanks anyway.
59wagon
Post
by 59wagon » Sun May 06, 2018 5:39 pm
Posts: 14235 Joined: Tue Jul 20, 2004 8:58 am
Post
by Blacky » Sun May 06, 2018 8:56 pm
couple of bucks at Pirtek or the like
Post
by Errol62 » Sun May 06, 2018 10:41 pm
thanks blacky
Dr Terry
Posts: 230 Joined: Sat May 21, 2005 6:41 pm
Post
by Dr Terry » Mon May 07, 2018 7:45 am
Be careful not to use a BSP plug here. The correct thread is 1/2" NPT, which is close to 1/2" BSP but not close enough. I've seen these housings split open by fitting a BSP plug.
Dr Terry
Posts: 5731 Joined: Mon Oct 08, 2007 2:00 pm
Post
by Harv » Mon May 07, 2018 8:13 am
Are these 1/2"NPT, or 3/8"NPT?
MasterParts reckons 3/8". I thought the 1/2" pipe plugs were on the water pump, but could be wrong.
