Ignition coil location
59wagon
Post by 59wagon »
Hi again,
The non-original motor that’s currently in the FB doesn’t have a bracket on the engine side plate to mount the coil - the original motor I have does.
The coil’s mounted on the brake and clutch lines, but this doesn’t look quite right.
Is that where it should be?
Thanks,
John
Re: Ignition coil location
early ones between 3-4 later ones between 4-5
paging Dr Terry...
There should be a mount on the side plate and corresponding bracket on the coil which slides down over the mount. Position varies somewhat randomly between spark plug holes 3 and 5.
John,
Your pushrod cover is FX-FJ.
But your ignition coil's from a red motor. It's supposed to have a ballast resistor in the ignition circuit, which your FB won't have. You'll be at risk of frying your points with this coil. Go back to a grey motor coil, or get a new 12-V, non-ballast-resistor coil.
isnt the ballast resistor hiding on the rhs of the coil rob?
edit: its not meant to be there with points, lol
59wagon
Post by 59wagon »
Thanks guys. So I think I need to get a SU12 or GT40 coil - anyone compared the two? Hey Rob, did the FJ’s mount the coil on the body somewhere?
Cheers, John
59wagon
Post by 59wagon »
SunnyTim wrote:
59wagon wrote:Thanks guys. So I think I need to get a SU12 or GT40 coil - anyone compared the two? Hey Rob, did the FJ’s mount the coil on the body somewhere?
Cheers, John
Yes FX FJ were mounted to the firewall hence sideplate with no coil mount
Sent from my SM-N950F using Tapatalk
Thanks, Tim. I’ll leave it where it is then until I swap motors.
59wagon
Post by 59wagon »
SunnyTim wrote:
59wagon wrote:
SunnyTim wrote:Yes FX FJ were mounted to the firewall hence sideplate with no coil mount
You can change the sideplate in less than an hour too....
Okay. Do I need a new gasket or anything else?
Dr Terry
Post by Dr Terry »
Hi Guys.
John, you must have better eyes than I have. How can you pick that coil as being a "Red motor" coil ?
It could well be an SU12, which is the correct 12V (non-resistor) coil for a Grey motor system. SU12 coils made in the 70s & 80s had the same brown Bakelite top as an SU12R. The only way to pick the 2 apart is the stamping on the bottom of the case which reads "Use only with resistor" (on the SU12R).
As the others have said the sideplate without the coil mount bracket is FX/FJ, the FE/FC one has it located between 3 & 4, while the FB-EJ one has it located between 4 & 5.
Dr Terry.
59wagon
Post by 59wagon »
Dr Terry wrote: Tue Jan 30, 2018 2:09 pm Hi Guys.
Dr Terry.
Thanks for the info, Doc. It was Rob (Ardiesse) that picked that coil as being for a Red motor. I had trouble just knowing which item was the coil!!
John
Dr Terry
Post by Dr Terry »
Sorry for the confusion.
Dr Terry
59wagon
Post by 59wagon »
This is the one off my FB, engine number B81600
