FC EK HK Steering columns wanted.
wot179
Post by wot179 »
Ive been asked to build a collapsible steering column for a mate with an FC ute.
Its currently got a front mount rack and an older Hadvield shortened column in it.
I reckon I can do the job if I can lay my hands on an FC-EK column for the top and a HKTG one for the bottom.
A little machining and a bearing and circlips on the bottom should see me right.
So Im after a couple of columns.
Any help appreciated.
Oh...Im making the assumption that FC and EK columns are the same...Im not concerned with what the steering box does as it will be discarded.
If Im wrong, straighten me out now.
Cheers in advance.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Craig Allardyce
Re: FC EK HK Steering columns wanted.
Post by Craig Allardyce »
FC column is longer (flat steering wheel) but essentially the same for the rest.
wot179
Post by wot179 »
Thanks for that, Craig.
It shouldn't make too much difference then so long as the top half is the same.
Cheers.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
collecta
Post by collecta »
I would have one here in Adelaide could cut the box off and send just the column if you cant find anything closer. Free just cover postage or swap for a HR wagon tailgate badge.
cheers
Scott
wot179
Post by wot179 »
That's a generous offer, Scott.
If nothing closer turns up I will take you up on it.
Cheers, Craig.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
bootlegger
Post by bootlegger »
If I have one out of a car you can have it Craig.
wot179
Post by wot179 »
Thanks, Dave.
I'll be in touch.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
rustysdungers
Post by rustysdungers »
You should haved grabbed one the other day when I was giving stuff away :esurprised:
Where were you in '62???
WayneXG95
Post by WayneXG95 »
Is this it?
wot179
Post by wot179 »
Im not on facebook so cant open the link, but its that grey ute that was at grey pride with the jap motor in it.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
FINK EK
Post by FINK EK »
Got an EK one here in not so sunny country Vic,it's all yours if needed, Gaz!
wot179
Post by wot179 »
The generosity of the blokes on this forum is outstanding.
Thanks fellas.
I think I have an EK column sorted.
Now to find a HKTG one as well.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
FINK EK
Post by FINK EK »
No probs,if anyone else needs it just PM me it's yours !
nes138
Post by nes138 »
Hi wot. This is exactly what I did. I also flattened the EK shifter so I could use the FC wheel. I have a rear mount rack and it's a bitch if a turn. Three uni and an eye joint...
Had Alien Auto make mine.
nes138
Post by nes138 »
