FC EK HK Steering columns wanted.
Ive been asked to build a collapsible steering column for a mate with an FC ute.
Its currently got a front mount rack and an older Hadvield shortened column in it.
I reckon I can do the job if I can lay my hands on an FC-EK column for the top and a HKTG one for the bottom.
A little machining and a bearing and circlips on the bottom should see me right.
So Im after a couple of columns.
Any help appreciated.
Oh...Im making the assumption that FC and EK columns are the same...Im not concerned with what the steering box does as it will be discarded.
If Im wrong, straighten me out now.
Cheers in advance.
Cheers in advance.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
- Craig Allardyce
- State: VIC
Re: FC EK HK Steering columns wanted.
FC column is longer (flat steering wheel) but essentially the same for the rest.
Thanks for that, Craig.
It shouldn't make too much difference then so long as the top half is the same.
Cheers.
Cheers.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
I would have one here in Adelaide could cut the box off and send just the column if you cant find anything closer. Free just cover postage or swap for a HR wagon tailgate badge.
cheers
Scott
cheers
Scott
That's a generous offer, Scott.
If nothing closer turns up I will take you up on it.
Cheers, Craig.
Cheers, Craig.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
bootlegger
If I have one out of a car you can have it Craig.
Thanks, Dave.
I'll be in touch.
I'll be in touch.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
- rustysdungers
You should haved grabbed one the other day when I was giving stuff away
Where were you in '62???
Is this it?
Im not on facebook so cant open the link, but its that grey ute that was at grey pride with the jap motor in it.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Got an EK one here in not so sunny country Vic,it's all yours if needed, Gaz!
The generosity of the blokes on this forum is outstanding.
Thanks fellas.
I think I have an EK column sorted.
Now to find a HKTG one as well.
Thanks fellas.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
No probs,if anyone else needs it just PM me it's yours !
nes138
Hi wot. This is exactly what I did. I also flattened the EK shifter so I could use the FC wheel. I have a rear mount rack and it's a bitch if a turn. Three uni and an eye joint...
Had Alien Auto make mine.
