Was told it came off a Grey from a FE?
Cain Manifold with a 2 Barrel Carb...
Ha ha FunnyTims on a roll....SunnyTim wrote:you would be better using a spaghetti strainer to feed fuel to the engine than a 350 Holley on a grey.
Is this for a grey strommie at 3"Hg? From the various bits and pieces I've seen, it looks like the value for the larger red Strommies (15/32" venturi) @3"Hg. The value I have for a grey (13/32" venturi) Strommie @3"Hg is 162cfm, which makes them approach being marginal at full-whack on a grey.Craig Allardyce wrote:A stock Stromberg is good for 210 Cfm.
Agree.Craig Allardyce wrote:Intake velocity speed is so important in maintaining fuel suspension in the air stream. Too slow and it drops out with the resultant problems.
G'day Harv, yep your right..............I plucked my figure from memory for the Stromberg. I was a tad bit out with that one. Should have known better at my age.Harv wrote:G'day Craig,
Big carb = big venturi = less pressure drop across the venturi = poorer atomisation = fuel dropout.
Big carb = big venturi = less pressure drop across the venturi = poor vacuum signal to the carb "guts" = sluggish response.
I really like vac secondaries... little carb at low noise, big carb when it needs to be.
Interesting that twins on a grey are probably slightly overcarbed. They need the venturi restrictors to pull them back a bit and increase response. They do however give better fuel distribution, which pays for some of the overcarbing/sluggishness.
