Rocker Cover Nut Size
Beerhands
Post by Beerhands »
Hey
Trying to work out what size nut I need for the two rocker cover hold down bolts if anyone knows or is able to check.
Alec
Re: Rocker Cover Nut Size
5/16-24 UNF.
Alec, Harv has sent you the goods...but..
Whatever you do - if you have the original tin rocker cover - don't overtighten those nuts! - it will buckle the cover and you'll never get it to seal....
Just a "nip" down and another check in a week or so when a new gasket beds in.
Many fit alloy rocker covers - not because they actually do anything for the motor.. but because you can screw those nuts down and get a reasonable seal around the rocker cover gasket.
Beerhands
Post by Beerhands »
Cheers guys.
Thanks for the information and warning. Going onto a speco finned cover and found some wingnuts that should look pretty swish on it. Thanks again for your help.
Alec
