He guys and girls would like so help on the best way to insall a sun visor, any help regards screws etc would be great help, even some close up photos of a fitted visor would be handy.
cheers jono
Installing a sun visor
Southern kiwi
- photo.JPG (157.83 KiB) Viewed 1859 times
Re: Installing a sun visor
Ripper looking wagon there Jono
Sorry no advise on visors, but will be looking at answers for my own reference.
This may help:
Notice that whilst the actual visor is common to all body types, the brackets are unique for sedan, wagon, ute and van. Getting the right brackets is the largest source of angst.
Harv.
Harv.
Southern kiwi
cheers for that great help, yes nice wagon brought about a month ago.
history was brought in aus about 8 years ago by perivous owner he spent alot of time and money on a full rebuild on drive gear did a respary etc,
brought over to nz to find it needed alot of work and money to get a cert.
so now its my turn to finish the old girl off, got new carpets going in next week also trim going on outside in next couple weeks.
next yera i plan to do a re fit on the seats and doors once i save some coin.
cheers jono
cheers jono
Hey Johno
As far as attaching the brackets to the body goes, I found the best solution is a "Nutsert" device. If you aren't familiar, it's like a blind rivet gun which installs a rivet-like device, but it's hollow and has a thread in it. They can be alloy, mild steel or stainless. My engine bay has heaps of these critters where I mounted fuel pumps, filters, header tank, relay panels.... I used this on Trevor's wagon when we fitted the visor, and it worked well. It leaves you with a nice threaded hole where you want it. A rubber "O" ring between the bracket and the body is also a good idea.
I used "wellnuts" - a brass thread fitted into a rubber tube, commonly used on motorbikes to fit fairings etc
http://www.google.com.au/imgres?hl=en&b ... 130&ty=100
- State: SA
I hope I might be able to offer some help? The brackets on my ute were rather dodgy so I made a pair of outer brackets (scalp brackets) from 0.8mm aluminium. See http://www.fbekholden.com/forum/viewtop ... 11&t=17288 of what the end result was.
I have also included some photos from my father's FB sedan. As we have had the car since Dec 1962 we know the brackets (stainless steel 0.5 mm) are original and not been messed with.
- Visor bracket 2.jpeg (30.39 KiB) Viewed 1739 times
- State: SA
The other photo
- Visor bracket.jpeg (30.36 KiB) Viewed 1737 times
