Help choosing diff
NZ_EK
Help choosing diff
Post by NZ_EK »
Hi, I'm after a bit of advice on what sort of diff to go for with my ek, I'm planing on having a red 202 with period type go fast bits eg triple carbs and I'm thinking that a 5 speed of some sort would be cool (celica?) but I'm not really sure which way to go with the diff? any advice would be muchly appreciated
JK
Re: Help choosing diff
Easy conversion is HR.
Volvo disc rear with a bit of welding.
NZ_EK
Post by NZ_EK »
not too worried about discs on the rear, is hr the same width etc?
wot179
Post by wot179 »
Early Hilux is a bolt in but you will need a stud pattern change as Hilux is fraud pattern.
Dunno if they clear 13 inch wheels but they definitely clear 14s.
Lots of ratios available but the common ones are more suitable to drag racing(4.1,4.3,4.5 etc)
Lim slips are available but expensive.
They are identical width to a HR diff and the saddles are in the same place as HR as well.
Flat flange type yoke which as its Toyota like your sillycar 5 speed,should make shortening a standard Hilux tailshaft a cheap and simple execise.
You will have absolutely no chance of busting one with a red street engine.Ever.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
HR are the same width as stock.
It will take a street red no probs :thumbsup:
fb cruisin
Post by fb cruisin »
wot179 wrote:Early Hilux is a bolt in but you will need a stud pattern change as Hilux is fraud pattern.
Also to add, Hilux have a 8 inch crown wheel.4.5's are out of a 2.4 deisel, and 4.3's out of a 2.8 deisel.
4.88 are the strongest Hilux centre with a 8 tooth pinion. You can pick up 4.1 out of V6 4Runners.
Broken quite a few of all of these, but not in a Holden :wink:
Cheers Rob
______________
living the dream.
NZ_EK
Post by NZ_EK »
Awesome, sounds like an hr diff is gunna be the easiest way.
cheers for that
JK
ekwags62
Post by ekwags62 »
Did some measuring today with the Volvo diff I have here for my rod project. They are popular with the rodders due to the strength and width, I beleive they are a Dana. EK drum face to face measures 1415mm, Volvo diff hub face to face 1405mm and are the same stud pattern. Was hoping that someone had already done this conversion using the IRS set up also have an LH Torana diff here so I'll get the tape out tomorrow and check as i'm looking to use the Torana front suspension also a common conversion to the Torana front suspension is Impreza power steering.
ek ute
Post by ek ute »
Read in Street Machine that early 90's Skyline / Pintara rear is very close to same width as HR; has disc rear but 4 stud. Need to grind off all the fittings. any one tried this option?
Patrick
Theres a few over this side of the paddock running Skyline diffs, with the axles redrilled to 5 stud.
ek rat
Post by ek rat »
my mate has an eh and we put a centura diff in it.which i put a spool in. was narrower so he moved the centres of the wheels in the rims. it had drum brakes and 28 spline axles the same size as a vn commodore. hence the spool.tuff diff. should never break.
Centura diffs were pretty popular in their day , but its getting real difficult to get brake parts for them now.
choppedfan
Post by choppedfan »
Blacky wrote:Centura diffs were pretty popular in their day , but its getting real difficult to get brake parts for them now.
Bloody hotrodders claimed them all :lol: :lol: :lol: :lol:
Mick 8)
fb delivery
Post by fb delivery »
I have fitted a few of these B W diffs ,
to XK TO XP fowlcoons over the years
neatride
Post by neatride »
I'm currently halfway through putting xf falcon discs onto my centura diff(in my project EK), but for the cost and ease having a reputable shop cut down a bw from a commo or falcon (IN MY OPINION) would be the best money spent especially for parts and reliability,cheers, Nick. :) 8)
Yes dear, just like you said. Theese are the words of an understanding marrige.
