G'day all. heres an easy one. can someone tell me which hose goes where? this is out of my EJ. had it disconected ages ago, cant remember how to hook up?
thanks sam
www.fbekholdennsw.com
I was told the hose at the bottom of heater goes to inlet side to help stop air being trapped in the heater that's how I did mine anyway
BILL
BILLY BLACKARROW
Hard to tell from photos but at a guess I would say yes mainly it is just to bleed the system of air
BILLY
BILLY BLACKARROW
B to D is what Billy is suggesting. The amount of air trapped is going to be pretty negligble - most of the time it doesn't matter whether B is connected to C or D.
Sam.
The std EJ brass bodied, cable activated tap mounts on a pipe about 4" long which goes in the 1/2"BSP threaded hole in the top of the cylinder head water jacket just inboard of the carby ie where you have marked ' C' . Things may get a bit confusing if it only has one threaded hole but I think they were much earlier heads - if that is the case then I have no idea short of some complex plumbing,lol ?
From there, when the tap is opened, the water will flow through the heater hose to the heater inlet pipe closest to the control valve on the heater itself, flow through the heater as nature intended, then exiting and returning through a heater hose and back to 'D' (water pump).
Dave Mac
Hi Sam
I just modified my post which is hopefully clearer. It probably doesn't matter much which pipe you connect with hoses at the actual heater but the other stuff stands. Right now you just have the water outlet (on the head) joined to the inlet (on the water pump) via a length of hose.
Dave Mac
While you are working out your options plug both the outlet and inlet on teh engine and loose the hose - it is the unecessary weak link in your cooling system.
