Red Rattler Revamp
Re: Red Rattler Revamp
They are VE Commodore boot hinges Melly , I have a couple more sets here that I was planning to use on the trailer and the 2 door but I am looking at a different setup now for the 2 door.
Red Rattler Revamp
Got the hinges fitted up and working close enough today - first bit of progress in weeks ….. ImageImagebonnet fits in the hole - sorta - going to have to knock up some shims to space the top radiator support bar away from the guards to open the gaps up a bit , be a terrible shame to scratch it ImageImage
Looking forward to seeing this beast in action soon.
Good to see a little progress mate wish I could say the same :roll:
FireKraka wrote: Mon Oct 16, 2023 10:25 am Good to see a little progress mate wish I could say the same :roll:
Yeah its been pretty slow going lately, too much other stuff getting in the way, the last 2 weekends have been taken up rescuing a mate from down Collie way with a dead slave cylinder in his Colorado, then removing the gearbox to replace , getting supplied the wrong bits , and finally this weekend getting it back together and driving , and managing a couple of hours yesterday after finishing we got the bonnet hinges sorted
Yeah, I had to space the radiator support panel as well.
Can't wait till you start repainting it Mr Blacky. :D :D :D :D
EK283 wrote: Mon Oct 16, 2023 6:30 pm
Get comfy Greg, you might be in for a fair wait :lol: :lol: :lol: :lol:
I guess you both did some mods to the bars, and they have shrunk. I’ve never encountered the issue.
Blacky wrote: Mon Oct 16, 2023 7:06 pm
:clap:
The things you see in your shed - had some visitors on Tuesday
look what the cat dragged in hey :lol: :lol: :lol:
Check his pockets before he leaves 🤔
Managed to get half a day in on this thing today- after a pub lunch with Western Wagon, his Mrs and another club member and his wife Image
Have a few more sensors to fit to the motor to keep the tuner happy-
First up was an inlet air temperature sensor, has to go in the inlet manifold under the supercharger….
Off with the blower - again - and drilled a pilot hole
Had to drill a 12.5mm hole access was shite , and my angle drill only has a 10mm chuck so had to machine down the drill bit
Drill bit sorted ,, finished the hole and ran a 14x1.5mm tap through it and job done.
Next was the knock sensor, figured this was going to be an easy install - should have known better ImageImage the old coil mount in pad was the chosen area , problem is it’s a 3/8” bolt and the knock sensor has a 5/16” hole in it .
I thought about drilling it out but without knowing what is inside it I figured it would end badly- so seeing I had the covers off the lathe I grabbed a 3/8” bolt and got to it
Started by cutting the head off , put 2 nuts on the thread and machined the shank down to 5/16” OD
Then hunted around the shed for the 5/16” UNC die because the bloody thing wasn’t where it should be Image
Gave up and grabbed the 5/16” UNF die and ran it down the bolt - while I was doing that I looked over on the bench I was working on and there was the 5/16” UNC die under a bit of crap on the bench …..
Test fitted it and the 3/8” end was a bit long so took a couple of threads off it - finished product
And installed -
