GMH Body Id Plate, Chassis & engine No ..... Please post.
samprinci
Re: GMH Body Id Plate, Chassis & engine No ..... Please post
Post by samprinci »
artyfartymarty wrote: Would love to know more about the history of the car if you could please tell me what the tag numbers mean.
hey,
I'll give it a go, but Im no expert.
225 = this is the number GM use for sedans
7782 = this is the number off the production line, your sedan was the 7782 off the line.
A = Adelaide. your sedan was manufactured in Adelaide
the rest of the number are paint & interior trim codes. refer to this thead:
http://www.fbekholden.com/forum/viewtop ... f=23&t=929
hope this helps, & if I have made any mistake, guys please correct me
ciao
Sam
www.fbekholdennsw.com
Aussie Bob
Post by Aussie Bob »
Well done Sam :)
Paint .... 585-9692 = Colleen Green 585-0004 = Sherwood Green
Trim ...... 608 = above 886= Amulet & Scarab Green with Stardust Grey Bolsters
I love this car as it is in the Burgundy mist !
Steve
artyfartymarty wrote: REGO states engine number as B90463 (is this original or the red 173???) where to find the numbers?
that engine No would be for the original engine, yor chassis No is on the right inner guard pretty hard to miss as the No's are quite large there's a terminal block for the headlight wiring it'll be just near that
and the engine No if you look on the engine just above the right engine mount it'll be stamped on the flat surface there
thecraig
Post by thecraig »
Hi Guys,
I have just found a pic I had stored away of the id plate on the EK.
It is probably the worst one on here but would love some info if you can read it!
Craig
Plate
Plate
mr.jones
Post by mr.jones »
I'll have a crack
Body EK 225 13658S
Trim 741 1023
Paint 585 9931
Insert PO 478A
Top 585 0246
So EK Special Hydramatic
Twilight Turquoise with Snowcrest lid http://gallery.oldholden.com/Mr_Jones/F ... Turquoise/
Mosaic & Jewel Turquoise trim http://gallery.oldholden.com/Mr_Jones/F ... +Bolsters/
Hopefully I have all the numbers correct
Leroy
thecraig
Post by thecraig »
I reckon you've got it Leroy. The interior is definitely that colour and pattern.
Which part of the plate designates that it is a hydramatic?
Thanks for the info!
Craig
mr.jones
Post by mr.jones »
The insert line has PO 478A, I'm fairly sure the way it works is
PO = Production Option
478 = Hydramatic
A = Special
Leroy
SheilaShoe
Post by SheilaShoe »
Getting all these bits and pieces ready for rego so I thought I'd post these up:
VIN: FB53706M
Engine No: B47853
Shelley :)
Aussie Bob
Thanks all for the tags and Chassis, engine numbers.
I will be posting up an update of the spread sheet in the next few days.
Anyone that wants there cars details on the register needs to be quick :)
Steve
Aussie Bob
Please see below as I enlaged the text so I could read it :wink:
Aussie Bob
I will try a little bigger :)
minifb
Post by minifb »
Looking Good steve..
FB/EKForum member 123
mr.jones
Post by mr.jones »
Nice work Steve :D :D
Thanks for sharing makes interesting reading when you have them all lined up, do you know if 225 and 229 production was counted separately or together; seems an awful lot of FB 229's built (around 50k) if they are separate?
Lerpy
FBeing
Post by FBeing »
Good stuff Steve
Don't think you've got the one in this thread:
http://www.fbekholden.com/forum/viewtop ... 12&t=12398
fbvan
Post by fbvan »
Decode this for me. And add to your register.
Body FB 2104 6037 A
Trim 511 829
Paint 585 9895
Chassis No. FB 43298 S
Engine No. J 35837
's 001.jpg (19.05 KiB) Viewed 3122 times
