There’s nothing worse
Re: There’s nothing worse
Next
Take that layer off -
More rust
Last patch made and fitted
Got 2 more welded in and called it a day
Blacky wrote: Wed Jan 01, 2025 2:13 pm HHHHMMMM - be a lot easier to tek screw the bastard in - chop the bottoms off them and a bit of seam sealer and nobody would be the wiser ImageImage
i nearly just fiberglassed the rusty rear floors on the current EK, dynamat on top underbody paint underneath good for another 10 years :lol:
Mick wrote: Wed Jan 01, 2025 10:09 pm
I bought a 1 tonner years ago , when I checked it out prior to purchase I lifted the carpets up to check the floors out, they looked fine - months later I had the thing on a hoist and the floors were rotten - turns out someone had bought 2 new floorpans and just sat them on top of the original floors - the only thing holding them in was gravity :lol: :lol: :lol: :lol: :lol:
Well done mate, nasty when you find things under other layers hey.
You are not wrong- and it keeps on giving….
Finished off the drivers side plenum repair this morning
And figured I would do the roof next ImageImageImage
What a bastard….chopped out a section
Only to find lots more
Chop chop chop
Bit of CAD work
That’s note pretty :crazy: :crazy: :crazy: :crazy:
What a horrible fiddly prick of a job this is …….
Had to remake the drip rail using a thin sliver of the original as I can’t press the shape with the gear I have here - it has taken all afternoon to make a piece of steel 240mm x 35 mm ImageImageImageImage
Got there - had a few goes at getting the first crease right with the bead roller
Then folded the rain gutter pressing
Trimmed to size then got the roll over to the roof sorted
Cheated and made it lap under the turret skin and glued it in - bog will fix the rest of it
Very tricky work mate. Not hard to make waves.
Errol62 wrote: Sat Jan 04, 2025 9:26 pm Very tricky work mate. Not hard to make waves.
Bog will fix it :lol: :lol: :lol:
funkyscooter
Post by funkyscooter »
Tricky bit of fab there Blacky - nice one!
Scott
Nice one mate.
