There’s nothing worse
Than running out of projects- apparently ImageImageImageImage
Just to make sure I never find out if that’s true I bought this today
Re: There’s nothing worse
I am the third owner , the fella I bought it from has had it for 30 ish years, it’s been pretty much parked up and only had occasional use for the last 10 - has some rust issues and needs bushes and brakes, the usual stuff. Image
Hasn’t made it to 200,000 km yet , not bad for 46 years old- is very original, has a aftermarket radio, the original rims and hubcaps are there , it has a cheap tachometer under the dash and one mystery switch- apart from that is stock as a rock 202 3 on the tree - just the way the good lord intended Image
That is a great score, it’s a good thing your retired and experienced in multi tasking projects 👍
Very nice.
Is the nanna blanket on the front seat needed (heater core shagged, or front seat torn)?
Any plans for a period correct bogan resto (Caprice front clip, 350/350, Armourlites, Kenwood sticker on back window)? :lol:
Old girl alright !!
Just a couple of days work and you could have it looking like this.
Please no Greg!
Westinghouse White. HZ with the RTS and not quite as bad as the HX on the anti-pollution spaghetti-fest. I had a van version. Good on the highway but hard to park.
At this point its fix the rust and touch up the paint, do the brakes - it does stop well and pulls up straight but the pads and rotors are very old , rebush the front end and cal it done.
I DO however, have an LS1 and a conversion kit in the shed :twisted: :twisted: that and a rear mounted turbo or 2 and here we come drag challenge :twisted: :twisted: :twisted: :twisted: :twisted:
Model. HZ8WM80 (version II identification plate as no spaces, HZ model, 8 for Holden, W for large size vehicle, M for luxury level, 70 for body style with M80 being a Holden coupe utility, not Kingswood which is N80)
Body No. 445474-A (A for Adelaide assembled vehicle)
Trim. 1930-67C (Buckskin and Dark Buckskin trim)
Paint. 563-30521 (Palais White)
Top.
Eng. L20 (3.3L High Compression engine)
Trans. M15 (3 speed manual transmission)
RRAXLE. GV7 (3.55:1 diff ratio)
Thank you Dr Harv 8) :thumbsup:
WesternWagon
Post by WesternWagon »
Nice score, 8)
Member : Holden Car Club WA.
:ASRF Member
You can’t help yourself can you Blacky
FireKraka wrote: Sun Jul 28, 2024 9:28 pm You can’t help yourself can you Blacky
You say that like its a bad thing :lol: :lol: :lol: :lol:
Never mate.
Seeing as the rattler was at a standstill again I tore into this instead- want to get the rust sorted out and rebuild the front end for rego purposes
