LS1EK
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Harv wrote:
TAZ wrote: Sat Apr 18, 2020 10:24 amI double checked Blacky. Am I missing and other bits that go in this area?
The bonnet catch lives in there, but the plunger doesn’t come down below the support bar.
Do you need to run a thermo fan(s) in there, or is there enough room between the radiator and LS1?
Thermos are mounted on the back of the radiator. Bonnet catch has already been modified.previously to clear the radiator etc.ImageImage
Sent from my SM-J730G using Tapatalk
Re: LS1EK
TAZ wrote: Fri Apr 17, 2020 6:49 pm
Blacky wrote:Will that fit behind the grille Simon or are you building a custom one ???
It will fit cobber. How are you and ya mate getting on from FB. Too bad he did not live near you , as you could had gone around and taught him some manners ImageImage
Yes he could certainly do with it - he ended up looking much like the goose he is though :ebiggrin: :ebiggrin:
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
So finally decided on where to mount the remote electric water pump. Followed up by mounting both the condensor and trans cooler (still needs a bottom bracket). All up a productive day. side.Image
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
So I have sat the guards back on and fitted the bonnet as I wanted to see if the truck style manifold would fit. With little work it will fit easily.
These manifold give a good HP and torque increase over the standard LS manifold. They can also be made to look quite good.ImageImageImage
Will
Re: LS1EK
Post by Will »
Looks wicked what’s the manifold called?
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Will wrote: Wed May 06, 2020 9:44 pm Looks wicked what’s the manifold called?
They are the manifolds that come on the LS truck motors. I am trying to get TBSS manifold as they are the best flowing OEM LS manifold due to the long runners and are relatively cheap
Re: LS1EK
Looking good Simon
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
So, who knows about doing bumper bars. I am going one piece with no over riders. I would like to know if I have to get all the joints flat and smooth or will the chrome guys do some magic and feel the joints so it becomes a nice smooth surface etc.
I also made some windscreen demister grills, better than paying $80 for a pair.ImageImageImageImage
Re: LS1EK
Hi Simon,
Great work I must say.
In my dealings with chrome plating the guys want a perfect finish so they can dip and collect the folding stuff.
The better you get the steel for them the better the job will turn out. They do grind and polish but that takes time and money. With your talent you should be able to get them pretty good, file finish would net great results.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
EK283 wrote:Hi Simon,
Cheers mate. Grind, sand and file it is then ImageImageImageImage
Re: LS1EK
One piece bumpers will look great. A lot of prep work I suppose, but if you want to get new chrome, be a good way to go for something unique.
Re: LS1EK
Vents look good. Any chance of some more detail Simon? They look milled.
Re: LS1EK
Nice work there
As Greg said best to do the prep work yourself on the rear bumper. Enjoy reading and seeing your skills unfold on this one mate. Thanks :thumbsup:
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Errol62 wrote: Sun May 24, 2020 10:30 pm Vents look good. Any chance of some more detail Simon? They look milled.
4mm ally, jigsaw, battery drill and a file is all it took. Considered getting them milled at work but wanted them done.
Re: LS1EK
Oh, didn't realise there are grilles. Did you use original diffusers underneath?
