Building 454 ute
454ekute
Re: Building 454 ute
Post by 454ekute »
Hello All,
Front end completed and I am now looking to install a 700r4 auto for the over dive advantage of this model.
I have a question re installation of a HT=HK Auto column as I want to fit this for compliance with collapsible steering but also to retain the original look of the shift.
Has anyone had experience in fitting one of these columns?
Thanks in advance.
wot179
Post by wot179 »
Just check which column will suit you better, as HK and HT/G auto columns are different.
HKs have a little pointy up bit (technical term) moulded to the coffeepot, HT/Gs have a wire needle indicator.
Ive encountered this issue having a HT column in a HK....I need to jerry something up to have a useful indicator.
Cant help on fitting one into an EK though...sorry.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
nes138
Post by nes138 »
I have a HK bottom with an EK top courtesy Alien Auto Columns.
And a straightened shifter to fit an FC wheel
454ekute
Post by 454ekute »
Thanks for the advice, ill be doing the same and adding the Ek top so it keeps the original feel.
Appreciate the pictures as well.
454ekute
Post by 454ekute »
Thought I'd post a pic of work in play to allow front end completion old section was gone, will need to repair hole(s) under battery tray section next
Fabricating new rails for fitment of front end
body 1.JPG (85.73 KiB) Viewed 2861 times
nes138
Post by nes138 »
Battery move to boot!
Rebuilder
Post by Rebuilder »
Yep, battery in the boot, brake booster under the guard or dash same with washer bottle , wiper motor and anything
Else you can manage. You will be surprised just how hot it gets in that little bay with a v8. More air moving around the better.
454ekute
Post by 454ekute »
Yes battery moved to the back, hi ace booster and pedal assembly under dash. wiper motor under dash as well, I want a clean engine bay but will be tight for room with everything mounted under the dash including heating/cooling.
CHOPPED
Post by CHOPPED »
i used a similar set up
with a bell crank brake pedal set up
same as some of the vans run
my wiper motor is under the dash also i used a gemini unit which gave me 2 speeds
had to modify the linkage arms to clear the booster
i have nothing on the firewall
as you said
makes for a clean engine bay
most people look at it and ask
does it run :shock:
HEY IT WASNT ME
454ekute
Post by 454ekute »
its been a while so i thought i'd add some pictures of progress... I've been a little time poor but at least things are starting to move a long a bit.
454ekute
Post by 454ekute »
front end mounted awaiting spring and shocker set up
454ekute
Post by 454ekute »
More pics.. note picture is inverted as car is upside down on the rotisserie...makes like easier when fitting front end an IRS rear end set up
unnamed (2).jpg (54.6 KiB) Viewed 2470 times
454ekute
Post by 454ekute »
setting out IRS cradle
Good to see some progress mate - how much do you need to narrow the Jag stuff to fit underneath ???
454ekute
Post by 454ekute »
Narrowed XJS front end around 110mm used an E type rear and cage fits within the chassis rails just needs to be adapted to fit using factory mountings
