Have we stumbled across the very first Walkinshaw ???????
Steve - does the van still have a motor in it which would require a bit of extra clearance where this "turtle" scoop is ? Perhaps the PO needed some room and he had this thing lying around, is there a hole in the bonnet under it ?
Although the bonnet does look like it came off a Sedan and not a Van, It still looks like a cheap way to get air down the throat!!!
Cheers Theo Z..............
but how much air ??? the hole in the fronts a bit small - those vents are designed to extract air by creating a low pressure zone directly underneath them and drawing air through the hole in the back - it would probably hurt performance rather than enhance - no wonder those early walkys never did any good at Bathurst
Is there a hole underneath it ? If you moulded it into the bonnet instead of the self tappers it would look kinda cool and fairly period correct.
Maybe block off the rear hole ?
