Bonnet scoop
Have we stumbled across the very first Walkinshaw ??????? :lol:
Steve - does the van still have a motor in it which would require a bit of extra clearance where this "turtle" scoop is ? Perhaps the PO needed some room and he had this thing lying around, is there a hole in the bonnet under it ?
thropzed
Post by thropzed »
Could be onto something here!!!
Cheers Theo Z................
FB/EK Car Club of QLD.
vhcruiser
Post by vhcruiser »
Imagebigger,not always better.
thropzed
Post by thropzed »
Here Blacky, This will show it some better light!!!!
Cheers Theo Z...................
thropzed
Post by thropzed »
Although the bonnet does look like it came off a Sedan and not a Van, It still looks like a cheap way to get air down the throat!!!
but how much air ??? the hole in the fronts a bit small - those vents are designed to extract air by creating a low pressure zone directly underneath them and drawing air through the hole in the back - it would probably hurt performance rather than enhance - no wonder those early walkys never did any good at Bathurst :lol: :lol: :lol:
vhcruiser
scoop
Post by vhcruiser »
This bonnet with scoop was on a ute I think. This van at the moment has a 149 with x2 set up .
Is there a hole underneath it ? If you moulded it into the bonnet instead of the self tappers it would look kinda cool and fairly period correct.
Maybe block off the rear hole ?
vhcruiser
Post by vhcruiser »
It has a rough as guts hole under it. As it was when I got it.
I saw two on top of a Mitsubishi van the other day, I would throw it away :wink: , Trev 8) .
