Diff identification
Re: Diff identification
Webers don’t go with a tall diff Col. Otherwise should work well as long as it has good bottom end torque.
What gearbox ? If you are running a fruity red and an overdrive box with 15" wheels a 3.55:1 centre will give you good off the line jollies and a decent cruising gear as well ???
Sneezy1211
Post by Sneezy1211 »
Errol62 wrote:Webers don’t go with a tall diff Col. Otherwise should work well as long as it has good bottom end torque.
Thanks mate may have to look at a ratio change .
Sent from my SM-A546E using Tapatalk
Sneezy1211
Blacky wrote:What gearbox ? If you are running a fruity red and an overdrive box with 15" wheels a 3.55:1 centre will give you good off the line jollies and a decent cruising gear as well ???
Hi mate
Celica 5 speed steel case box
Sneezy1211 wrote: Fri Aug 23, 2024 9:49 pm
Hi mate
Celica box and 15" rims I wouldn't go any taller than a 3.55:1 mate
