My EK project
searsy
Re: My EK project
Post by searsy »
Trev wrote:How about some spacer blocks in the engine mounts (between top and bottom bits)?
how about a couple of small light taps with a big sledgy
I mean just masage the sump a little bit
searsy
Re: My EK project
Post by searsy »
Mick wrote:as trev said HR will only make things worse, yor engine is set up to far forward 1. you can't fit a fan and 2. yor steering hits, yor just gunna have to live with it or move yor engine mounts
why doesn't the EJ collum fit :econfused: i've put many in with no dramas
dis regard my previous comment engine mounts r definitely to far foward
Re: My EK project
Post by Mick Jagger »
phuck :x
x more than $*#@ 3
then the carb will hit the firewall
ill make a sump
or keep it quiet so nobody knows :shh: :shh: :shh:
kmawic
Re: My EK project
:shh: :shh: :shh: :shh: :thumbsup: :thumbsup:
no officer this model falcon had a bad turning circle
kmawic
Re: My EK project
it shouldn't be to bad, not that often you need full lock, you want bad turning circle try a hadfield rack :shock:
Re: My EK project
thought about it whilst not sleeping
i can either A.move the mounts back and make/modify the gbox mount but the shifter will hit the seat,carb the firewall etc
or B.bend a bit of steel over some pipe and chop the sump and weld it in
Bloody cars...Q.if I slam on the brakes how far forward will the motor and box move?...i have 9mm :oops:
between waterpump bolts/radiator(Not a 9mm cock)
I have to move it back. :(
Mick the steering box holes arent in the same spot,close though
Searsy ,good idea but Im far to proffesional for that shinnanagins,although a massage sounds nice :wink: :wave:
kmawic
Craig Allardyce
Re: My EK project
Post by Craig Allardyce »
why not move the radiator forward??? :?: :?:
Re: My EK project
cause of the lock down thingo
kmawic
Re: My EK project
heres some pics
put them
on the fucin stickly red motor thing
kmawic
Craig Allardyce
Re: My EK project
Mick Jagger wrote:cause of the lock down thingo
I moved mine forward and managed to keep the standard lock position for the bonnet. Just made up a new radiator support. I utilised the gap forward of the standard radiator position right up to the bonnet lock bracket. The radiator sat on the beaver panel and under the radiator cross support. Grill still fitted ok as well. Fans sat behind radiator where they should too.
My motor sat well forward so I could fit in the manifold and trimatic without any cutting.
Re: My EK project
:shock: :shock: :shock: :shock: :shock:
thats a moo0n buggy
kmawic
Sputzwagon
Re: My EK project
Post by Sputzwagon »
:wtf: :wtf: :wtf: Mk 2 Cotina Grill?????? :wtf: :wtf:
Woofto Car Club Member No 2
Re: My EK project
Im requiring to purchase an fj holden grill,but they are few andfar between :( :( :( :( :( :( :( :( :( :( :( :( :( :( :( :( :( :( :( :(
Dont you like the cortina grill :sick:
kmawic
Re: My EK project
I like the cortina grill :thumbsup:
Probably means you won't use it :lol: .
I have about 10mm between my fan and radiator too.
Use an Eh to HR fan, they don't flex.
I used a HQ one and it ate my radiator :evil: .
Sputzwagon
Re: My EK project
Mick Jagger wrote:Im requiring to purchase an fj holden grill,but they are few andfar between :( :( :( :( :( :( :( :( :( :( :( :( :( :( :( :( :( :( :( :(
I did'nt say that I did'nt like it Jase...just that it was obvious to me where it came from. :wink:
Scotty.
