The loooonnng term EK 2 door project
Re: The loooonnng term EK 2 door project
Looking good!!
Roof line looks great Blacky.
Had a go at cutting down a windscreen today - started by making a template of the timber screen to transpose the shape onto glass
Then used it to mark up the victim …..
I bought a sanding disc that is specifically designed to sand glass, it fits in a 5” grinder , used it in a cordless machine and ran water over the glass.
It works a treat , only took a couple of minutes to remove this much glass ImageImage
Before
After
i think keeping it cool and slow and steady is the trick
i know an arsey bloke that cut an old second hand chev screen with a 1mm cutting disc (nowhere near the curve of an FB/EK screen) but still just picked up the angle grinder and just cut it like he was cutting a piece of metal
Mick wrote: Sun Jul 28, 2024 10:29 pm i think keeping it cool and slow and steady is the trick
A mate of mine did exactly the same thing on an XP ute front screen - I was actually going to try that on this screen but seeing how well this disc gets through it I am going to use the sanding disc rather than take the risk with the cutting disc. it leaves the edges a bit ragged but I reckon a bit of 240 grit at the end ought to smooth it off.
Well you did the smart thing and not follow what I did .
Can you share the details of the disc please?
Might be handy for others to use.
This is the disc I used , picked it up in a bargain bin at a local supplier so not 100% sure where to source them from
Is a 16 grit which kinda explains the roughness of the finish, will see if I can find some smoother grade discs to finish it off with.
Did you grid down to the line or cut along the line?
What ever gets the job done.
ground down mate, long sweeps to keep the heat away
Have you trial fitted the screen?
How’s the body mods going?
Sort of - I took the screens over last week and we laid the front one in - it’s close but not spot on , and now I have buggered my hip up and I am out of action for at least a week :esad: :thumbsdown: :thumbsdown:
The cartilage is buggered - I have to meet with a hip surgeon next Friday to see where I go from here :evil: :evil: :evil:
Found this on instagram Trev, thought you might be interested- I see you liked it a couple of years back??
Blacky wrote:Sort of - I took the screens over last week and we laid the front one in - it’s close but not spot on , and now I have buggered my hip up and I am out of action for at least a week :esad: :thumbsdown: :thumbsdown:
Basically what I’ll do.
Getting old is not for whimps.
I’ve had both knees replaced and now hips are giving me the shits it sicks getting old
That was supposed to be sucks
