Help boot hinge spring
I have an FB sedan with a broken boot hinge spring, and I'm having alot of trouble trying to fit a new one, without losing a finger.
Does anyone have any tips or suggestions on fitting this?
cheers Rob
cheers Rob
Re: Help boot hinge
Hi Rob one of the guys in nsw fefc club has come up with something that might http://www.fefcholden.org.au/cgi-bin/ya ... 68986283ay help you,regards Greg.[/url]fb cruisin wrote:I have an FB sedan with a broken boot hinge spring, and I'm having alot of trouble trying to fit a new one, without losing a finger.
cheers Rob
Re: Help boot hinge
Thanks Greg, What a great idea.blu_fc wrote:Hi Rob one of the guys in nsw fefc club has come up with something that might http://www.fefcholden.org.au/cgi-bin/ya ... 68986283ay help you,regards Greg.[/url]fb cruisin wrote:I have an FB sedan with a broken boot hinge spring, and I'm having alot of trouble trying to fit a new one, without losing a finger.
cheers Rob
So all you do is drill out the original pin bolt in these and set the tension with an allen key.
I suppose it would make it easier to give springs that have lost a little tension a bit more of a wind up.
cheers Rob
Guys I tried the link and it didn't work. Said the topic no longer exists. Would love to see this other idea.
Regarding the spring tensioning tool, I've decided maybe I should bite the bullet and have sent the drawing to a bloke who is going to make up maybe a few of them for us.
Andrew.
Andrew.
Whingeing won't fix it.
- Contact:
Greg thanks for that great idea.
Andrew try this link...
http://www.fefcholden.org.au/cgi-bin/ya ... 1168986283
same one as Greg posted above except no 'ay' at the end of it.
Stewart
Stewart
Boot Spring Posts
Hi guys,
I have more of these available again. This is what they look like:
(note there's a star washer included not shown in that pic)
and here's one as fitted to a vehicle, prior to painting:
These fully adjustable items do not require the special tool shown previously, and won't cost you a couple of fingers trying to fit them!
Price is $35 for a pair, which includes pins, star washers, nuts and fitting instructions. Postage (within Australia) is $5.
Send me a PM if you'd like to order a set.
Thanks,
RET
Thanks,
RET
finally fitted my adjustable boot spring pins.
even if I made the tool my springs needed a little more tension than the factory setting.
I found with my FB it was easier cut off the pressed pin with a 4 inch grinder and re drill.
thanks for the pins Richard
well worth the $$ to eliminate your nasco boot prop
cheers Rob
cheers Rob
