3 sp linkages
Miss EK
3 sp linkages
Post by Miss EK »
hey all, i have recently gone to drive my car and was not able to select any gears and my gear stick was all floppy. I had my better half have a look and 1 of the linkages has come off at the steering box. i was wondering if anyone could help me out cause we dont know how it reconnects?its the linkage that is shaped like a w.
thanks
miss EK
Miss EK
Post by Miss EK »
SunnyTim wrote:sounds like your linkage has come of the steering box selector rod. This bolts on if it is the one that goes into the back of the steering box, but I fear they have a bad habit of snapping which means you need to diasassemble the steering box and replace the selector tube...Yuk - or fit a floor shift. Hopefully it is the simpler option and its the other selector rod and it is just that the split pin has come out....
Best of luck
Ummm i think its exactly wat u described :( how do i go about fixing this??
Thanks
Miss EK
Post by Miss EK »
SunnyTim wrote:need to pull the steering column apart and remove the selector tube and replace with another one. My advice is to get a workshop manual as it tells you how to do it with diagrams. NOt a job for the faint hearted
ok, wat would be the best manual to buy with the diagrams?
FB MAD
Post by FB MAD »
Gregorys workshop manual no 67 ( 1948 - 1968 ) , should be able to order it from most spare parts shops for around $50 or so new or around $30 2nd hand at swap meets or evilbay.
or genuine GMH FB or EK Holden workshop manual usually available from Evilbay or swap meets and usually sell for around $60 average price for good usable 2nd hand one.
Miss EK
Post by Miss EK »
i have ordered a manual and waiting on arrival, wat can we start on while we wait? how do i pull apart the steering column?
thanks for the help
Miss EK
fb cruisin
Post by fb cruisin »
I had to replace the selector tube on my fb 6 months ago.
i went 3rd to second and got nothing :roll:
To cut a long story short its a 2 man job to fit the arm at the bottom (after replacing the tube), and make sure you get the felt seals in the right place :wink:
______________
living the dream.
thropzed
Post by thropzed »
When this happened to mine, I just ripped out the whole column and replaced it with another. Simple and easy when you have the spares. Took about an hour tops!
Cheers Theo Z.....................
FB/EK Car Club of QLD.
FB MAD
Post by FB MAD »
:roll: I did the same thing as Theo did when mine played up :roll:
Just swapped another column assembly in.
Can be a time consuming, rectal pain causing repair at times.
Miss EK
Post by Miss EK »
thanks for the replys, so wat your all sayin is that i need to get another steering column? anyone have one? otherwise i dont think i will be fixing it :(
thanks for the help
Miss EK
FB MAD
Post by FB MAD »
Would be best to try and get a column up near where you live if possible as freight can be a killer even on relatively light-ish parts like a steering column.
Righto you Queensland mob, show us ya columns!! :lol:
