LS1EK
Re: LS1EK
You can buy my rotis mate if you want one :lol: :lol: :lol:
Re: LS1EK
FireKraka wrote: Mon Aug 04, 2025 12:37 pm You can buy my rotis mate if you want one :lol: :lol: :lol:
You are going to need it for the sedan mate :lol: :lol: :thumbsup:
Re: LS1EK
I think I might have had one to many ales last night Blacky :lol: :lol: :lol: :lol:
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Finally got some epoxy on some metal. I am using the resto finish product and you can use it as a high build product. I have actual rolled it on as it will be rubbed back anyway before I apply the final sealer to it. Rolling it means no need to mask anything up and stops paint going everywhere in the shed.
Also got around to finishing the fuel tank and just have to do a pressure test on it to check for leaks.
LS1EK
Looking good taz
Re: LS1EK
I love the underneath of this car
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
This afternoons job, sand back all remaining parts of the chassis and then spray some epoxy on.
Also have the block, pistons and conrods back from the machine shop.
Re: LS1EK
Getting there mate :thumbsup: :thumbsup: :thumbsup:
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
So, been a bit busy and despite best plans nothing is painted. Anyway bottom end of the engine is together and I finished lapping in the valves tonight.
Some progress at least.
Re: LS1EK
its all progress mate :thumbsup:
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
So heads back together, had to make my own double valve spring compressor 😁😁.
Note the valve spring retainer wedge into the underside of the head.
I spent 1.5 hours looking for that mother $*#@…..heads go on to the assembled bottom end soon. Engine builder reckons it should be good for about 330 kw at the wheels 😁😁.
Re: LS1EK
Backyard mechanics at their finest 😎😎👍👍
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Right so back to work after a long hiatus due to summer surf sports and working on the sons XR6 turbo.
Paint stripped the whole front using Coopers paint stripper, this stuff is excellent and eats through bog as well. I am stripping it as I did not have faith in the work that the previous owner had done. So glad I did as there is surface rust everywhere.
Will sand and hit with metal treatment before resanding and apply epoxy.
Re: LS1EK
Ah the memories,
Its funny how the surface rust can be under what apperars to be good paint !
Chemical treatment like deoxidine will help contain it and of course the epoxy seals extremely well. Most of the acrylic stuff was porous so no surprise there is some activity, you will find this on most unrestored cars.
Great job Taz.
Re: LS1EK
G’day Simon?
Lot of positive comments about the Coopers stripper. I’ve been using this. Image
Now time to restock. It takes off all but this red etch primer that is under everything else st least on this, my very late production Adelaide EK van. Image
The red then requires a bit of effort with the dirty old clean and strip disc. Image
Slow speed on a polisher so as not to overheat panel but also, avoid melting the disc. This is the bit that dicks with my scapula. Trying to look after the shoulders, being another old surfer.
