Buckskin FB panel van
Re: Buckskin FB panel van
Phil Ivanov came and got the rear floor section got some play money for Bendigo.
Nearly finished the dash.Image
Not much left now.Image
I'm curious as to the significance of the 333 at the bottom of the tag.Image
Could it be side windows?
333 is tailgate window option.
Thanks Harv, very interesting. Never seen van with no tailgate window.
I’m be never driven one, but they reckon a blind van has really poor visibility of traffic alongside/behind.
Dr Terry
Post by Dr Terry »
333 was a regular option in FE/FC, because they came standard with an all-metal upper tailgate as standard, with the glass as an option.
In my experience there were more vans with the glass option than without, but maybe it was different back in the day.
I don't believe this was the case in FB/EK, the gate itself was made differently to FE/FC & the glass was a standard fitting.
Maybe because this van is such an early production build (168-A), the 333 was still being stamped in early FB.
Dr Terry
Thanks Dr T. I thought same, carry over from FC.
Finally rear brakes off. Drums are very good meat wise. One may require truing up a bit. They were hell to get off. Finned ones...Image
Drastic measures....ImageThat pretty well completes the deconstruction. I don't suppose anyone is in need of a stock 3.89:1 centre? There is a run to the scrap merchant due.
If the diff housing is off to the tip can I grab the bump stop brackets please??
Very handy for Torana diff swaps 😎👍
Easy done blacky.
:thumbsup:
Hey blacky did you get the diff ends I sent via Neil?
Errol62 wrote: Wed Feb 07, 2024 3:20 pm Hey blacky did you get the diff ends I sent via Neil?
I got a couple from Gazza a few weeks back ?????
I sent them with the Tramp rods. Speak to Neil.
