Buckskin FB panel van
Picked up this early FB van yesterday, which I am eying off for rear quarters for the other one. In some ways, it is better than the EK van was when I picked it up, mainly in the passenger rear quarter, roof, and window surround. I will strip it down and consider its future. Firewall forward is toast, though bonnet may be OK. Uppertailgate is ok. Lower is probably salvageable if anyone needs one. Has a tank but dented. Smells like varnish, which may be a good sign. Nothing in the way of an interior but the remnant of a head lining, EK special dash, good wheel and horn bar. Another front window. Now have four.ImageImageImage
Re: Buckskin FB panel van
It is even earlier than the Sydney FB215 I used the dash out of in the EK van. It has the heater hole over where the regulator normally is. The coil is mounted to the inner guard. The dash above the ashtray doesn’t have any ribbing. Floor looks better than the EK on initial glance but sills are well gone of course.
Smooth dash looks weird …….
Agree Blacky. Commercials usually started production months after the model run began so you'd expect to see this on more sedans, except you wouldn't notice on specials. I'd want to put special trim on it if I was using that dash . Pretty fancy having indicators fitted though.
Front floors and doors are rusty but jambs are there. Above the doors and screen are full of nesting material, but no poo or carcasses yet. And mmum still hasn't noticed it yet. Living on borrowed time.
funny of the countless ones i've owned i've never seen a smooth dash
Clay
If you let the grass grow no one will know you have another stashed around the back of the shed 👍
The good......Imageand only reason I bought the thing really.
The bad:ImageImage
The rear floor is mainly ok as vans generally are and will yield a good repair section for anyone with a rusty ute rear. The front floor is rusty, but I've seen worse, my EK van, for instance. The rear seat area above the front leaf spring mounts is bad as it often is. Tank looks ok from the top, but I know it is dented underneath. Doors are rusty. Roof looks good on top but heavy scale underneath, and the upper side panels where the vnts are are rusted away on the inside.
It is definitely for the chop....
Forgot these.ImageImageImage
Anyone need original brake stuff? If not there is a bloke on facebook that is chasing stuff.
Hey Clay that van doesn't look that bad at all :roll: :roll: :lol:
Yes it depends what sort of an eye you cast on it Neil. The rear floor and inside panels are not as good as the EK was when I got it. Most of the cover plates are rusted at the bottoms, as well as the rear pillars and cornice bits. Front floors, plenum, window surround and A-pillars are a bit better. All the hanging panels and front clip are pretty bad, other than the bonnet. The guards are about 50% rusted away. Subframe is very bad. Upper tailgate repairable. Fuel tank has some minor dents but looks ok. Lower tailgate is very bad. Haven’t had a good look underneath yet but the inner and outer sills are stuffed.
oz_ek
Post by oz_ek »
Errol62 wrote: Tue Sep 26, 2023 6:10 pm
Clay I might be interested in the floor and tailgate.
Sure Phil
Clay has anybody got dibs on the fuel tank yet??????????????? :crazy:
Moi ami.
But I've got a good wagon one if you want it.
Errol62 wrote:Moi ami.
Won't fit with the IRS though, will it?
