I still haven't finished making them .......avm wrote: Mon Sep 04, 2023 6:12 pm Hi there, Do we still have a couple of those contacts that I could buy? My EK's horn does not work and I suspect that the switch/contact area is responsible.
Horn contacts
Re: Horn contacts
Re: Horn contacts
I'll take a set when you get around to making them too Blacky if that's cool?
Re: Horn contacts
I had 20 of the contacts machined up so forum members and club members get first option , if there's any left they will be offered on Bookface - I may have to get more done I think , plenty of people chasing them ......
Re: Horn contacts
I haven't been on the forum for donkeys, my horn decided it didn't want to work today. I suspect it a contact issue! Logged on and saw your post... from... some time ago lol
If not enough that's fine, not on FaceAche so that's no go for me
Re: Horn contacts
Another thing - if there are parts of the horn mechanism that can be 3D printed, then I'd be happy to give that a try. All that I would probably need is for someone to either lend to me a sample of the part to be printed (even if it's cracked or worn), or for someone to supply me information about the geometry (e.g. scale drawings). For example (and a highly fictitious example): If the part consists of a plastic ring having 75mm outer diameter, 58mm inner diameter, total thickness 3.2mm with a 4mm square north cut out of the outer edge at the 12-o'clock position, then that's the sort of thing I should be able to model and print for testing.
Project ICKPA.
Re: Horn contacts
I'm surprised more bits aren't 3D printed to be honest , the FB/EK chairs we raffled at the 2018 Nationals had some 3D printed parts in themavm wrote: Wed Sep 06, 2023 5:10 pm Another thing - if there are parts of the horn mechanism that can be 3D printed, then I'd be happy to give that a try. All that I would probably need is for someone to either lend to me a sample of the part to be printed (even if it's cracked or worn), or for someone to supply me information about the geometry (e.g. scale drawings). For example (and a highly fictitious example): If the part consists of a plastic ring having 75mm outer diameter, 58mm inner diameter, total thickness 3.2mm with a 4mm square north cut out of the outer edge at the 12-o'clock position, then that's the sort of thing I should be able to model and print for testing.
Re: Horn contacts
Putting my hand up 100% for a set of horn contacts, ready with payment when requested.
I don't have a headlight switch or original button or bezel either. Marty
Re: Horn contacts
Welcome to the forum Marty,motorhead wrote: Thu Sep 07, 2023 7:42 pm Putting my hand up 100% for a set of horn contacts, ready with payment when requested.
Headlight switches can be bought new , I have a couple here or you can get them from Rare Spares
Re: Horn contacts
Blacky, I think there are a queue of people waiting outside your shed for horn contacts……………… no pressure
Re: Horn contacts
yeah i may need to move this up the list - funny part is I got a couple from Dudleys yard at Nuriootpa nats so I dont actually need any for myself any more .......In the Shed wrote: Thu Sep 07, 2023 8:42 pm Blacky, I think there are a queue of people waiting outside your shed for horn contacts……………… no pressure![]()
Re: Horn contacts
You mean the brissy boys didn’t rat them all by then?
Re: Horn contacts
They got most of them but I still managed to find a few
Re: Horn contacts
OK kids - they are FINALLY ready
Not by me though - I was talking to a bloke in Perth about having sunvisor ends made and I mentioned to him that I was partway through making these things and he said that he would be happy to make them so I helped him out with a couple of things and now they are ready for sale.
His name is Richard and he owns a company called Billetworks, their main gig is building collapsible steering columns for earlies but he also makes lots of FX/FJ bits including hubcaps, FX grille badges , grey motor harmonic balancer removal and installation tools , etc etc .
Their number is 08 9309 2080 and the contacts are $75 including a new bush to fit into the steering wheel.
Re: Horn contacts
And here’s a picture
Re: Horn contacts
Good stuff blacky
