Project 2.
Re: Project 2.
Agree it woud be great if you cold use the HK worm shaft in the ek box. If you were to use the HK box and pitman arm you would have to use the HK idler arm to match the pitman arm. They are longer as I said but possibly not enough to negate the ratio change too much. Yo could possibly use the HK idler arm on the ek pivot pin in this case. All this was enough to make me decide I was happy with my steering as is. I drove a mates ute with rear mounted rack yhe other day and couldn't fault it. Better lock than standard, which was mainly what I was concerned about but for v8 front mounted is required and there is the rub. I wouldn't say the rack was any better than my rebuilt jobby.
funkyscooter
Re: Project 2.
Post by funkyscooter »
Great info Brett. Hope you can find a solution to make it work. At least it will keep things a little more 'factory'.
For a non factory option, I have started looking at electric steering units like this
https://www.flamingriver.com/fr40200-mi ... r-steering
Not at a stage yet to really fully consider, but its would be a tight fit with a collapsible column. Would need to fit it to the base of the column I think. Don't know if there is enough room between the steering box and the fire wall (assuming these units can be mounted in the engine bay). Early stages - need to sort out my steering box first. Or look at rack and pinion. Or do what I do when faced with the big picture problems - go back to cutting rust out of the car. Baby steps!
Scott
Re: Project 2.
I have looked at an under dash EPS unit, the column shift makes it more difficult but not impossible- there is a ute on here fitted with one . I bought a couple of them and it’s another “one day” project……..
Re: Project 2.
Heres an interesting read, it is for an american falcon but the concept is the same for all old cars,
I have a standard Torana rack in my car and it is awesome to turn whist moving but is hard standing still. When i get some time I will look at one of these electric units.
https://www.therangerstation.com/tech/t ... onversion/
The amount of work doing a steering box modification compared to one of these units i feel would nearly be the same.
Re: Project 2.
Yes I grabbed one of these to play with but not enough under dash room to even consider it.
gledge
Re: Project 2.
Post by gledge »
I’m gunna have to have a crack at EPS me thinks
funkyscooter
Re: Project 2.
This is what got me thinking of EPS in the engine bay
https://youtu.be/TpZkHs4Y5Ko
Scott
Re: Project 2.
Me too! If any one wants my unit send me a PM.
Re: Project 2.
This one for Clay who is fond of 'jugs'😆
briby
Re: Project 2.
Post by briby »
I like a big pair myself :wink34: :wink34: , but a beautifully worked out set up, well done Brett. :thumbsup:
FB Restomod V8 Sedan
Re: Project 2.
Nice one Brett…….. but I don’t see a bottle of Coopers stout 🤔
Re: Project 2.
Reschs Pilsner for me.
Tuning completed. Blue mixture and 1/3 up the tube for each. Easy peasy. Running sweeter than when on WW.
Belly760
Re: Project 2.
Post by Belly760 »
I’m intrigued. Got no idea what your doing there.
FB Ute Stock
EK Ute in Pieces
Re: Project 2.
Thanks Brett. Kept me entertained for 20 minutes looking at that. I’m using a similar throttle cable set up by the looks. I see the Holden manifold is water heated and you are only choking the rear carb, which should still give you idle up on all three due to rigid linkage. Tidy setup with the springs. I don’t like the way mine hang down under the carbs, sorry jugs, so may revisit this. I take it your throttle cable and lever aren’t fully set up in the photo, and you have the individual levers pulling the throttles. I’ve seen some set up to push but not sure about it. They turn the levers 180 degrees on the individual throttle shafts. Engine bay looks mint mate. Bit more exciting than the old WW.
Orange Betty
Re: Project 2.
Post by Orange Betty »
Belly760 wrote: Fri Jul 28, 2023 12:54 pm I’m intrigued. Got no idea what your doing there. Image
Same here. What is the 'jigger' you are using with the float tube thing??
Dave
62 EK Sedan in slow progress
