Micks chopped & tubbed ute
62MLOO
Re: Micks chopped & tubbed ute
Post by 62MLOO »
WRAPAROUND WINDSCEENS AND SQUARE QUARTER WINDOWS RULE !!
62MLOO
Post by 62MLOO »
Unfortunately the vents were rusted. One of them maybe salvageable but not much left of the other one.
https://hosting.photobucket.com/images/ ... fit=bounds
62MLOO
Post by 62MLOO »
found these on ebay. S/Steel reproduction. They look to be fairly well made.
Fancy farmer or tradie must have had that ute. Must have been the boss cocky’s car. Nice score.
You going to knock a vent up on Vulcan? Seriously though someone like Pete Mallaby should start making these. The repro ones weren’t cheap last time I looked.
62MLOO
Post by 62MLOO »
Yeah they werent cheap but but a quick easy solution. Sorry Im having trouble putting pics up. Can someone remind me how its done.
62MLOO
Post by 62MLOO »
new ventsImage
Sent from my SM-G981B using Tapatalk
you would think these days they would be a piece of piss to 3D print
62MLOO
Post by 62MLOO »
They definitely could be 3D printed. They wouldnt be that hard to fabricate from scratch either but the time it would take to make a one off pair wouldn't be worth it for me. Different if you were to make a batch of them.
62MLOO
Post by 62MLOO »
I always thought that the sun visor that came loose with my donor ute was actually off the ute as it is the same colour and the roof has the holes drilled in it. Turns out the brackets are a different profile and don't fit. Tried them on sedan roof and they fit perfectly.
So, anyone out there want to swap ute brackets for sedan brackets ? Also need the drivers side s/steel corner trim which is missing.
62MLOO
Post by 62MLOO »
62MLOO
Post by 62MLOO »
62MLOO
Post by 62MLOO »
Also,
Is there a way of removing the aluminium trim without destroying it ? I want to take it off so it can be polished and to paint the visor.
gpi
Post by gpi »
this bloke got his off but had trouble putting it back on
viewtopic.php?t=14680
Wrongway Roger
Post by Wrongway Roger »
Beware of what is under the trim. A little surface rust is the edge the more underneath.
This is my visor that will go back on Ammo's ute.
Visor 1.JPG (39.55 KiB) Viewed 8615 times
Visor 2.JPG (36.06 KiB) Viewed 8615 times
Visor 3.JPG (44.65 KiB) Viewed 8615 times
What looked to be fairly single repair to start with so I have patched on the inside but have yet to decide what to do on the edge.
I hand rubbed the trim to remove the corrosion with a view to anodise it but still in a raw state at the moment.
62MLOO
Post by 62MLOO »
Hey Guys, Some recent pics to follow. Body is mostly sealed up, and currently my sparky is doing his thing. Pushing hard now to get it finished by May Next year.
Now how do i post these
