Ammo's Ute
Re: Ammo's Ute
Errol62 wrote: Tue Jul 19, 2022 7:07 pm
Reckon that is Phil’s car blacky.
Oh - I got all excited for a minute :oops: :oops: :oops:
Wrongway Roger
Re: Ammo's Ute
Post by Wrongway Roger »
Don't need another blue ute on the road. Common as
Ammo said no green or shade of green.
Maybe this colour
Lightning silver.PNG (228.27 KiB) Viewed 1600 times
stinky
Re: Ammo's Ute
Post by stinky »
Wrongway Roger wrote: Tue Jul 19, 2022 4:44 pm Started playing with 2 speed wiper motors from early Corolla's after seeing Phil Grima's setup at the Nationals.
Peter Mallaby on the FE/FC Forum and Facebook does a 2 speed kit for FE/FCs inc new motor and all the bits, should suit FB/EK or at least be easily adapted.
Re: Ammo's Ute
Basically a BF Frod motor on ek mount plate, ek crank and after market switch. Pete machines up his plates and cranks but if you have a fused ek motor you can use the bits. The switch is the trick item and costs the same as the motor. The electrickery is different to ek and also has a push squirter function.
Keep thinking on the colour roger. My 2c... you're right about the blue ones though. Did Lenny put Ammo off green?
funkyscooter
Re: Ammo's Ute
Post by funkyscooter »
After mucking around trying to adapt a single speed EK wiper to a 2 speed with a step up transformer (12V-15V), I ended up getting one from Pete. It comes with a diagram of how to wire it and the switch up which is a great help. Only grumble is the switch knob makes it look a bit cheap. Will work out a way to adapt a knob from a stock washer switch when I can find one.
Step up transformer will go into the warmaride fan to boost the high speed, so not a lost cause.
Scott
Re: Ammo's Ute
Love the way the tank ended up Roger :thumbsup:
Wrongway Roger
Re: Ammo's Ute
Still undecided on the wiper motor but there is heaps of space on the left side of the glove box to play with.
Purchased a LJ Torana diff this morning. Just need to cut off the unwanted mounts and weld on spring saddles.
I'm hoping the brakes are a straight swap over as this one is lacking everthing.
LJ diff 1.JPG (146.76 KiB) Viewed 1511 times
LJ diff 2.JPG (91.39 KiB) Viewed 1511 times
Don't think I will have an issue with the 2.78 ratio as the motor is a blue 202.
Diff came out of Torana with a big block 161.
Re: Ammo's Ute
Straight swap to EJ HR brakes with a bit of pipe relocation. Tall diff will be good on the run to Perth. Don't go too tall on your back tyres. Be good with the auto.
Re: Ammo's Ute
The diff breather is tucked under one of those top mounts mate, careful you don't bugger it up when blasting the mounts off - ask me how I know :roll: :roll: :roll:
Wrongway Roger
Re: Ammo's Ute
I did see the breather inside of top- mount so I was carefully cutting, Blacky.
The guy who welded these mounts one way back, was either good backhand or forehand as the welds were very different from the left to the right.
Maybe 2 guys did the welding of the brackets.
As the ute is for Ammo, I'm sure the diff ration will slow her down a little off the line but cruise well.
Clay - thanks for the confirmation on the brakes. The brake lines have yet to be finished off so easy to change now.
Tomorrow is cleanup diff, paint if the weather holds and put out the current diff and remove the brakes.
I have a plan.
Re: Ammo's Ute
Good to have a plan Roger- I had one once😁. Enjoying the twist and turns of this build.
Re: Ammo's Ute
Coming along there roger. :thumbsup: :thumbsup: :thumbsup:
Wrongway Roger
Re: Ammo's Ute
I need to order a couple of spring pads to weld to the diff housing as I do not want to cut them off a good diff.
I was going to make these from 65 x 4 or 5 mm RHS but cheaper to grab a couple from Kustom Blitz in Melbourne.
I'm putting on new bearing as one seems to be very tight. No workshop press so using a mechanic down the road.
More progress next week. maybe.
Re: Ammo's Ute
Wrongway Roger wrote: Sat Jul 30, 2022 9:15 pm I need to order a couple of spring pads to weld to the diff housing as I do not want to cut them off a good diff.
I made mine , and made them an inch deeper than stock to lower the ute :thumbsup:
Re: Ammo's Ute
Pete Mallaby sells spring saddles on Evilbay Rog.
