Harv's FED thread
Re: Harv's FED thread
New shoes. Wheels still waiting on the courier :(
BS wrote: Sat Jun 11, 2022 9:49 am Crook as a dog with the flu lying on the couch watching the winternats live stream and seems to be a heap of front engine dragsters running in modified this weekend. Got me thinking how bloody cool it would be to see a grey powered front engine dragster in the mix!
Like this ?
National Motor Museum Birdwood.
Farken peeved I managed to miss that today. Would've liked to pop the bonnet on the merv waggott twin cam grey midget, but no...
As close to the Pure Hell FED as IHRA rules will let me 8)
Young bloke picked up the slide-and-glide yesterday (with thanks Brett). Date code shows it was made by McKinnon Industries in Canada, dayshift of the 1st of November 1968. Probably out of a HK, maybe HT.
Removable bellhousing so 6-cylinder version. Legend has it that some bellhousings were only partial circumference and prone to cracking (not sure which cars had that?) though this one is full-circumference.
Weighs in at 46kg dry and with no convertor/flexplate.
• a used grey crashbox, without oil, clutch or flywheel, weighs approximately 27kg.
• a used red crashbox weighs 21.0kg (6kg of this is the bellhousing).
• a used Aussie 3 speed weighs 27.5kg (without bellhousing).
• a used hydramatic weighs 47.5kg.
It needs to be cut down to a "shorty" version and manualised... be interesting to see how heavy it is after that.
Hope it performs well for you Harv.
Gaining momentum Harv
Timing cover leak drip tray Front engine mount:
front engine mount.jpg (90.94 KiB) Viewed 3381 times
Rear engine plate (needs trimming):
rear engine plate.jpg (122.09 KiB) Viewed 3381 times
:thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup:
You aren’t mucking around Harv
ekv8ute
Post by ekv8ute »
That block looks vaguely familiar Harv, things are moving along pretty well
ekv8ute wrote: Mon Jul 04, 2022 11:30 pmThat block looks vaguely familiar Harv, things are moving along pretty well
It should look very familiar (with thanks :thumbsup: ). The other one is still on the bench, being used for timing cover fuel pump mounting musings.
Focus this week is on getting the diff in. Hopefully in, and then back out again so I can drop it off to be narrowed and beefed up before going back to work again.
BS
Post by BS »
Making some progress Harv. It’s looking good!
Looking good Harv,
That chassis builder in Seven Hills by any chance ?
Yep, Richard Botica.
Tyres on:
This gives you an idea of scale…Number One Son’s VL front wheels are 19s. The FED wheels are Chev pattern… horribly close to Common-door. Suspect if his wheel wells were bigger then I would have come home to two worn-out slicks 🙄
