Moderators: reidy , Blacky
Posts: 14137 Joined: Tue Jul 20, 2004 8:58 am
Post
by Blacky » Sun Apr 17, 2022 1:46 am
Then I grabbed a piece of 100 x 6 flat bar to use for the bracket, had to make it 60mm wide through the base of the seat so I fired up the rotary plasma cutter and knifed the sides down - that’s that bit done, tomorrow will mount the console and paint it hopefully
Post
by Blacky » Mon Apr 18, 2022 12:01 am
Got the rest of it sorted today, but ran out of hifill primer - my panel beating skills or lack thereof means hifill gets used a LOT In my shed ……
Who would have thought a beer can was the perfect size to rub out the scallops on an FB seat side
all primed up with etch
Insert and cup holders done
BS
Posts: 454 Joined: Thu Jul 31, 2008 8:31 pm
Post
by BS » Mon Apr 18, 2022 7:07 am
Flash as
Posts: 2661 Joined: Thu Mar 16, 2006 9:51 pm
Post
by EK283 » Mon Apr 18, 2022 7:34 am
How much for the 2 door ??????
Posts: 5713 Joined: Mon Oct 08, 2007 2:00 pm
Post
by Harv » Mon Apr 18, 2022 7:44 am
That console looks awesome.
Pretty sure the bush chook will work as rust convertor... does a good job of pickling things
Post
by Blacky » Mon Apr 18, 2022 4:49 pm
gpi
Posts: 1131 Joined: Mon Apr 26, 2010 2:08 pm
Post
by gpi » Mon Apr 18, 2022 5:17 pm
does it mount to the 100x6?
Post
by Blacky » Mon Apr 18, 2022 8:42 pm
gpi wrote: Mon Apr 18, 2022 5:17 pm
Remove the cup holders and there is a strip of flat bar that screws to the 100x6
Posts: 2261 Joined: Wed May 16, 2012 10:18 pm
Post
by In the Shed » Mon Apr 18, 2022 9:37 pm
Nice work
Posts: 2782 Joined: Fri Jan 24, 2014 11:12 am
Post
by FireKraka » Tue Apr 19, 2022 12:25 pm
Looks good Blacky
Post
by Blacky » Tue Apr 19, 2022 6:42 pm
FireKraka wrote: Tue Apr 19, 2022 12:25 pm
Looks good Blacky
In the photos it does, not so good up close
Post
by Blacky » Thu May 05, 2022 6:00 pm
Seat is trimmed , going in tonight
Posts: 11550 Joined: Sat Dec 06, 2014 2:44 pm
Post
by Errol62 » Thu May 05, 2022 6:02 pm
Good timing seeing you’ll be sitting your arses in it for a few thousand km soon. Looks great. Style and comfort.
FbSTDwagon
Posts: 790 Joined: Thu Jul 02, 2020 3:04 am
Post
by FbSTDwagon » Thu May 05, 2022 11:16 pm
Absolutely sweet looking!
Drew
Post
by Blacky » Sun May 08, 2022 3:50 pm
Old seat out - oops moment - forgot about the bit that sits under the back window- found some Masonite in the shed , cut a piece to fit then off over to Drews to cover it in black marine carpet - will do for now but will redo it in blue later - also going to fill the seatbelt holes in the seat which got forgotten this time round.
