Anyone wrecking a ute?
oz_ek
Post by oz_ek »
Thanks.
vmx-mxr
Re: Anyone wrecking a ute?
Post by vmx-mxr »
I'm after that same section.
My FB's one has had the crap belted out of it by heavy things like oxy cylinders bashing the daylights out of it so if two become available I'm happy to go seconds :shock:
oz_ek
Post by oz_ek »
vmx-mxr wrote: Sat Jan 29, 2022 2:49 pm I'm after that same section.
The plan is to make a lower section from the upper.
oz_ek
Post by oz_ek »
Found.
vmx-mxr
Post by vmx-mxr »
oz_ek wrote: Sat Jan 29, 2022 3:02 pm
OK. I am lucky with the bottom but the top section is very bent up. Great you found one!
oz_ek
Post by oz_ek »
Any help?.... https://www.ebay.com.au/itm/28462935548 ... eid%3Dbf9d
There was a bloke on bookface yesterday who is currently gearing up to reproduce these panels
That'd be right seeing I finished repairing mine yesterday. Brett has probably put Sasha Stark on to it.
Innocent of all charges😁. A fellow called Brody Walker said he was going to make some. Sasha said he could make them if he had a template. Anyone with the right sized bead roller could make the bottom panel without any trouble. Top with the right angle maybe a bit more of a challenge.
oz_ek
Post by oz_ek »
Blacky wrote: Sun Jan 30, 2022 9:17 pm There was a bloke on bookface yesterday who is currently gearing up to reproduce these panels
I contacted him, he's unsure of when these panels will be available.
oz_ek
Post by oz_ek »
Errol62 wrote: Mon Jan 31, 2022 6:53 am That'd be right seeing I finished repairing mine yesterday. Brett has probably put Sasha Stark on to it.
Also contacted Sasha, needs an example or template to work from......So no luck there.
FJWALLY
Post by FJWALLY »
There was an fe/fc ute with all rust repair done on facebook today - not ek but a very good start if you could change direction
oz_ek
Post by oz_ek »
Mark Thomson is in the process of making the lower sections....
lower panel fe-ek.jpg (677.66 KiB) Viewed 3642 times
I’ve got one of those anvils 8 )
oz_ek
Post by oz_ek »
Errol62 wrote: Tue Feb 01, 2022 7:28 pm I’ve got one of those anvils 8 )
Really? :yeahhh:
