- P1070593.JPG (215.11 KiB) Viewed 3293 times
Anyone wrecking a ute?
Thanks.
Re: Anyone wrecking a ute?
I'm after that same section.
My FB's one has had the crap belted out of it by heavy things like oxy cylinders bashing the daylights out of it so if two become available I'm happy to go seconds
The plan is to make a lower section from the upper.vmx-mxr wrote: Sat Jan 29, 2022 2:49 pm I'm after that same section.
My FB's one has had the crap belted out of it by heavy things like oxy cylinders bashing the daylights out of it so if two become available I'm happy to go seconds![]()
Found.
OK. I am lucky with the bottom but the top section is very bent up. Great you found one!oz_ek wrote: Sat Jan 29, 2022 3:02 pmThe plan is to make a lower section from the upper.vmx-mxr wrote: Sat Jan 29, 2022 2:49 pm I'm after that same section.
Any help?.... https://www.ebay.com.au/itm/28462935548 ... eid%3Dbf9dvmx-mxr wrote: Sat Jan 29, 2022 2:49 pm I'm after that same section.
There was a bloke on bookface yesterday who is currently gearing up to reproduce these panels
That'd be right seeing I finished repairing mine yesterday. Brett has probably put Sasha Stark on to it.
Innocent of all charges
. A fellow called Brody Walker said he was going to make some. Sasha said he could make them if he had a template. Anyone with the right sized bead roller could make the bottom panel without any trouble. Top with the right angle maybe a bit more of a challenge.
I contacted him, he's unsure of when these panels will be available.Blacky wrote: Sun Jan 30, 2022 9:17 pm There was a bloke on bookface yesterday who is currently gearing up to reproduce these panels
Also contacted Sasha, needs an example or template to work from......So no luck there.Errol62 wrote: Mon Jan 31, 2022 6:53 am That'd be right seeing I finished repairing mine yesterday. Brett has probably put Sasha Stark on to it.
There was an fe/fc ute with all rust repair done on facebook today - not ek but a very good start if you could change direction
Mark Thomson is in the process of making the lower sections....
I’ve got one of those anvils 8 )
Really?Errol62 wrote: Tue Feb 01, 2022 7:28 pm I’ve got one of those anvils 8 )
