Valerie the EK Standard Sedan
Re: Valerie the EK Standard Sedan
Just using th chrome light for smock up I think Pat.
gpi
Post by gpi »
These should keep the marine life safe
AccuAir ? Top of the wozza gear :thumbsup:
gpi
Post by gpi »
its this kit with all the options ticked
https://airide.com.au/collections/early ... mplete-kit
8) 8) :thumbsup:
Wow
DaveEK
Post by DaveEK »
So I’m guessing 4 link ??
gpi
Post by gpi »
nope, just reset springs and a lowering block...
though i will talk to a couple of their recommended installers before getting defected on the side of the road...
DaveEK
Post by DaveEK »
You can do an airbag setup with monoleaf. That’s taking all leafs off except last one and that keeps diff located. I wouldn’t do but it’s a cheap way to get a cool look without 4 link. Otherwise you won’t get the drop you want.
I have had a couple of cars with airbag setups and a lot goes into fabrication to do it properly on the back.
This is my van
gpi
Post by gpi »
yeah thats about how high it needs to be
this one doesnt have a 4link either
http://fbekholden.com/forum/viewtopic.php?f=11&t=2518
DaveEK
Post by DaveEK »
Looks as though he did mono leaf setup. Neat setup though. My van has way to much done with 4 link , chassis notch and and tubbed. Looks like the ek will be a lot easier to get down!! Good luck very interested to see ur progress. You doing the install yourself? Where are you located
gpi
Post by gpi »
I can only imagine given the amount of customising I can see done on the outside Image
I’ve got this diff to go in too so should be good to just bolt it all in.
If it isn’t low enough I might get some help.
DaveEK
Post by DaveEK »
I am in two minds whether to airbag mine aswell. It does look awesome when done.
That diff will be perfect. Do you have to shorten to suit the ek
gpi
Post by gpi »
the more bagged the better!
there is a handy thread here on bw diff shortening:
http://fbekholden.com/forum/viewtopic.php?f=26&t=13199
gpi
Post by gpi »
