FB Standard Wagon
Re: FB Standard Wagon
Yes, horrible dirty rusty fibre- more likely plant than animal though Harv I'd guess. It doesn't smell like hair when it burns
From memory I think the coils around the pipes were in positions to protect from stone damage only and not all the whole length.
Back then there were lots of dirt roads and this contributed to the second issue of collecting dirt. I always have a chuckle at the guy behind the counter saying things like, all they did is collect dirt and rust !! That's right 40 years of collecting it to rust, imagine the inside with the moisture absorbing brake fluid.
Fast forward to today and your hard pressed to find a good old dirt road nor will I drive on one ( that I think ) so I have not installed the coil, no modern car that I have has this type of protection.
Re FIREWALL KIT.
I saw that after buying a kit from them before and wanting another one.
The 'price' is to keep the listing going while they wait for boards to come from the USA suppliers.
Normal price was $90 plus post and I was very happy with mine, and shipped very safely too. Kick panels are also quality gear.
"You couldn't buy the materials for that"
Dave Mac
Dave Mac
Yes I paid about $90 from memory. I have tried mob with foam backing and also fibreglass type stuff. Both were ok for the large panel but the smaller one wasn't the same shape as original.
Everybody's kick panels seem to be ok.
Could buy card from Daley’s and use for a pattern. Prolly don’t need the “horsehair” if you dynamat.
So spoilt now you can buy everything but $$$
card is back in stock now i believe, $150 buys the kit and kick panels he makes from memory and yes it has a big ticket price on it just to keep the listings happening as per ebay policy while replenished, you'd question the high price if you really wanted kit i guess.. but you never know these daysvmx-mxr wrote: Mon Dec 06, 2021 1:25 pm Re FIREWALL KIT.
Dave Mac
Cheers Becky
FbSTDwagon
Goog morning fine Holden heads!
It’s been a bloody busy week between work, the Holden and doing some house hunting but I’m back on afternoon shift so that gives me the mornings where I can burn the candle at both ends I. The shed for 8 hours and then go drive trains for another 8 haha.
So thanks for the robust discussion about the insulation pad on the firewall. I just took the easy option and removed the horse hair and hacked into some of the floor pan felt that I have got and glued it on to the cards.
It all worked out pretty good… or good enough I should say.
I had to get this job done as the smaller insulation piece on the drivers side needed to be fitted before the handbrake assembly under the dash went into position.
- B371E299-037C-41DC-A24D-4CDC19B42163.jpeg (143.92 KiB) Viewed 829 times
- 6257F817-A3F0-4ADC-9C45-4EB82EEBB5B4.jpeg (90.89 KiB) Viewed 829 times
Drew
FbSTDwagon
The next job was to get the rest of the handbrake mechanism and cable into place under the car so I could ensure the brake lines would not interfere with it.
Once that was in place I went ahead with finishing the brake lines. I made a few boo boo’s and had to buy some more Bundy tube so the job didn’t go to budget but I got there in the end.
Sure hope none of it leaks as I don’t want to be doing this job again!
- 6326403A-41DC-430C-BCD2-712A1A2BBF15.jpeg (121.46 KiB) Viewed 826 times
- 52CDF1C8-35FB-474A-9E9F-E28D4F1FD42A.jpeg (99.76 KiB) Viewed 826 times
- 6D16AE5D-6187-454D-B0A5-24C12548C4B6.jpeg (127.81 KiB) Viewed 826 times
- 30F74420-3349-4111-90E0-151799E61904.jpeg (126.47 KiB) Viewed 826 times
- 634BC194-3A5F-4943-A9C5-2F7CE428D1F3.jpeg (124.87 KiB) Viewed 826 times
- BDBCE63C-AED3-45F8-B660-08E3DE3574D3.jpeg (135.11 KiB) Viewed 826 times
- 948B48D6-A6CE-4AE1-9E9C-10D6D4EB9979.jpeg (146.15 KiB) Viewed 826 times
- FA3743F5-FE87-48CF-BD30-392DD67B95EF.jpeg (125.35 KiB) Viewed 826 times
Drew
FbSTDwagon
Next up is the brake line on the rear diff housing for the rear brakes. I’ll get into that today… hopefully first time lucky this time!
Drew
Looks great mate, I made new brake lines for the rattler but they look horrible so i am going to do them again ... jobs not done right until its been done at least twice
The tube is not too dear so the odd rejected prototype is no drama.
Looking very tidy, P clamps and all.
FbSTDwagon
Yeah compound radius and the angles needed to make it all fit make it job that is actually done 3 times to get it right!Blacky wrote: Mon Dec 13, 2021 9:32 am Looks great mate, I made new brake lines for the rattler but they look horrible so i am going to do them again ... jobs not done right until its been done at least twice![]()
Like punching yourself in the face really…
Drew
FbSTDwagon
Not too dear but it adds up fast.Errol62 wrote: Mon Dec 13, 2021 10:18 am The tube is not too dear so the odd rejected prototype is no drama.
Would rather do it and get it right though.
Drew
